Question about Panasonic CQ-C1305U CD Player
Wiring Need to know where the amp turn on wire is in the stereo plug
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 2,226 Answers
Amp turn on wire is usually blue/white.
Posted on Apr 29, 2013
88 vette aftermarket head unit stereo wireing diagram
Might be able to get an adaptor that plugs straight in painlessly.
Failing that it's the standard trace and identify method that eats time like crazy.
Apr 16, 2017 | Cars & Trucks
Silverado radio wiring
Some trucks and gm cars have two kinds of systems one without a amp,and one without so judging by what you're saying you probably have one with a amp so yes you can but it is complicated and you would need to bypass amp so just get the kit that's required for your vehicle.
Jan 14, 2018 | Cars & Trucks
'97 rodeo-Must jump 2 middle wires in stereo plug to get tail lights to work
Are you the original owner ? Did it have an after market radio installed ? If yes, it might of had wiring connected wrong from there.
Jul 21, 2017 | 1997 Isuzu Rodeo
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
No sound dual xhd6420 92 accord lx
my brother has a 1993 Honda accord and had the same issue, we put it different speakers and it worked fine, don't know what the problem was but it worked
Feb 12, 2010 | Dual Electronics XHD-6420 CD Player
I need to put a new sony stereo into my daughters Lanos and need to know what colour wires do what in the exisitng plug in the daewoo
Here are the wiring colors but just before you connect it please make sure the colors match
1999 Daewoo Lanos Car Stereo Wiring Guide
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Dark Green
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Right Front Speaker Positive Wire (+): Brown/White
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Right Rear Speaker Positive Wire (+): Dark Blue/Black
Right Rear Speaker Negative Wire (-): Yellow/Dark Green
Jan 04, 2010 | Daewoo Lanos 1999 Car Radio/stereo...
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
Need wiring instructions for vbx12a
You will need the following:
A power wire (preferably 4 or 8 gauge) with an inline fuse (typically 50amps)
A battery terminal adapter to connect the power wire
A signal wire to let the amp know when the stereo is on
RCA audio cables to connect the amplifier to your stereo
A ground wire for the amplifier (again 4 or 8 gauge preferred)
Walmart sells a Scosche kit that has all of the wiring as well as a basic diagram for about $25, but it does not include the battery terminal adapter.
If you have a factory stereo you won't have RCA ouputs, so you will need a line level converter. A basic one like the Scosche SLC4 usually runs in the $20 range. You splice into your speaker wires and run them into the unit, then plug the RCAs into it.
Mar 08, 2009 | Visonik VB-10PKG Car Audio Amplifier
I`M REPLACING THE ORIGINAL RADIO ON A 1996 GMC JIMMY, I NEED TO KNOW WICH WIRES ARE WICH, (ALL THE POWER ONES) OLD RADIO NOT AVAILABLE
PLEASE RATE MY SOLUTION, THANKS.
1996 GMC Truck Factory
Stereo Wiring Chart
Car Stereo Dimmer Wire: Gray
Mar 08, 2009 | 1996 GMC Jimmy
Panasonic CQ-C1305U CD Player Logo
75 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
