Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Merlin P230T, gear not working
When pressing remote controller button, light on but the gear was not working and the door didn't move
myob247
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
SOURCE: Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
Posted on Nov 10, 2008
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
  • 3197 Answers
SOURCE: remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
Posted on Apr 14, 2010
  • 244 Answers
SOURCE: My merlin 230T won't open or closes with remotes
Unlock the LOCK
Posted on Jul 11, 2010
Merlin M802 remote not working it has a new battery and the red light flashes when button pressed but won't open or close the door
need to reprogram it to the opener. push the 'learn button' then push the remotes button. door should then respond.
Dec 22, 2015 | Building Materials
How to program a remote control for Merlin Garage Door
Each manufacturer of aftermarket remotes for Overhead doors has a specific sequence for a specific door opener mfg and model #. And those sequences are include in the printed matter in the packaging of the remote. If you have Merlin remote and Merlin opener contact the local Merlin installer for the sequence.
Oct 13, 2014 | Building Materials
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
Liftmaster Model 1265-67 stopped working with the remote after I repleaced the drive gear. Nothing was changed but now the unitl opens and closes perfectly with the wall switch but I can't get the...
Make sure the light in the wall control isn't blinking. That would be an indication that the lock function is on. To turn it off, press and hold the lock button for 3 seconds.
Oct 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin powerlift-model 2500L Garage door and cannot find the Learn Button to program my new remote. Please help...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
