Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
"E 1 code error
Hi I have a LG LD-2131 SH free standing dishwasher. It has been running fine for some time now but only recently has been cutting out, discharging whatever water was in the machine and displaying the E1 error code. I have detached the input hose and checked the water pressure through the hose and found it to be functioning properly. Can you perhaps help me overcome this problem. Thank you.
  • 2 more comments
  • Anonymous Feb 13, 2008
    e 1 errotr code
  • anneke1 May 16, 2008
    My dishwasher doesnt pump water into the machine and then show an E1 error? What should i do?
  • Anonymous May 25, 2008
    have the same problem today. Not happy.
  • tool4u Jun 07, 2008
    water not pumping through at all and dixplay showing E1 error. how to solve this
When there's a leak in the BASE of the machine where does the leaking water go, on the floor?
Posted on Apr 22, 2008
  • 183 Answers
The fault is that the anti flood device is activating, you have a leak somewhere in the base of machine. Regards Engineer
Posted on Aug 05, 2007
Our washer stops (cut out) after the first wah on all programs - We purchased it less than a year ago
If your dishwasher is less than a year old, it's possible you still are covered by the manufacturers warranty. If you still contain your date of purchase, it's possible you can call for LG OEM service.
Is your unit displaying any sort of error code on it?
Mar 06, 2011 | LG 24 in. LD-12BW5 Free-standing...
Hi, I need a manual for LG LD2131 SH
Hi
Thanks for using FixYa. You can download the user manual for your dishwasher from this link--
LG LD 2131 SH Dishwasher User Manual
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | LG Dishwashers
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
Sep 06, 2008 | LG 24 in. LD-12BW5 Free-standing...
ERROR CODE "TE"
The MOSt common reason for a "tE" error code is the temperature of the hot water from the hot water heater is greater thant 145 degrees (F)
Adjust your hot water heater down and measure the temp at the kictchen tap.
Good Luck!
Aug 26, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
"E 1 code error
E1 is a drain error. On the unit prior to mar 07 LG had a problem with wires breaking in the door. Turn off power supply, remove door panel and look for wires stuck in the insulation. Check continuity of the wires, if broken, splice and tape. Place insulation between black insulation and wires to prevent reoccurence.
Sgt 48
May 24, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-14AT2 - Error message about filter
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Nov 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
494 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Marvin
Marvin
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
