Question about Water Heaters
Water not hot enough - Water Heaters
  • Water Heaters Master
  • 5,245 Answers
Add a comment and describe brand, type and model of product.
Also say if this is new installation or older installation
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Posted on Apr 26, 2013
Heater not getting hot enough
Open the access door to the thermostat ( about 3" wide & 9" high, two screws) At the bottom of the thermostat there is an adjustment screw on an arrow and dial. Factory settings are at 120% for residential heaters. Reset to 135% is hot but it will not scald anyone. Higher temps are dangerous especially to those used to the old setting (if there are 2 doors reset both thermostats)
Jan 31, 2015 | Water Water Heaters
Water is not getting hot enough
thermostat set too low.
leak in hot water line or hot water being used too fast.
defective thermostat
Dec 09, 2014 | Reliance Water Heaters
NOT GETTING HOT ENOUGH
Copy following link to identify type of water heater:
http://waterheatertimer.org/How-to-fix-water-heater.html
Gene
h
Jan 20, 2014 | Premier Water Heaters
The water never gets hot when on normal settings
This time of year the water comming in the house is much colder and heater has to work a lot harder to heat 40deg. water than ot does to heat 70deg water in the summer time. its normal.
Jan 09, 2013 | Water Heaters
MY Rheem 81SV40D Water Heater (47 gal) does not heat enough water. Approximately one bath worth.
You have dual-element 240Volt electric water heater.
Since you have some hot water, then we know upper element is good, and that circuit breaker and electricity to water heater are good.
Not enough hot water is probably bad lower element, and possibly sediment build-up in bottom of tank.
Test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace 4500 watt element available at local hardware, and clean out bottom of tank:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Oct 07, 2012 | Rheem Tankless Hot Water Heater...
I installed a 30 gallon gas hot water tank and sometimes i get strong water pressure but my hot water doesn't last long enough for 2 showers, but if i have low water pressure we can get in 4 showers. Any...
At a high pressure you are consuming more hot water. It sounds to me like the water heater isn't big enough for what you need. You can try turning up the heat thermostat on the water tank. If the water gets hotter you won't need as much for each shower and it will also recover faster at a higger temperature.
Mar 26, 2011 | Whirlpool Water Heaters
Check out this tip about adjusting the water temperature on electric hot water heaters...
Electric Hot Water Heater Temperature Adjustment
heatman101
Oct 11, 2010 | RELIANCE ELECTRIC WATER HEATER
Water is not hot enough and the temp is on 120 I have a notiz tankless hot water heater
check your gas pipe size. make sure you have enough gas running to the unit. also turn all your faucets on hot and turn off the cold water to the heater and see if you get any water out of the hots anywhere, that could mean that you have a cross connection.
Aug 24, 2009 | Noritz Water Heaters
Bosch TF250 hot water service
Replace the flame sensor.
May 11, 2009 | Bosch Water Heaters
At shower time in the morning the hot water varies from cold on one day medium on another and hot on any given day. What's wrong?
Do you share your hot water with anyone? Is anyone washing dishes, laundry, etc before you shower? How old is your hot water heater? If it has filled with sediment, your hot water is limited. Try turning up the heat control valve on the hot water heater, only go up one notch today, then if not enough another the next day. Be cautious of scaulding hot water after turning it up.
Apr 10, 2009 | Water Heaters
Water Heaters Logo
13 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
