Question about Stanley 54ZS 726cc 24 HP Gas 54-in Zero Turn Commercial-Duty Riding Mower
Stanley 54" zero turn mower throws belt
Throws driveshaft and blades belts off
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Why won't the blades engage on my riding mower 54" mtd 13ap625k730?
You have probably thrown the belt for the blades. If it continues to throw the bet check the tensioner.
Aug 10, 2014 | Mtd Garden
When I turn off the blade on my JD L110 riding lawn mower the belt continues to turn the blade and thus throw the belt off. Why???
worn pullies and belts can cause this as the belt sticks in pully and then throws off because of tension removed from belt
Sep 13, 2013 | John Deere L100 Series
Belt diagram
It only have one belt if it is the mower in your profile pic. I have the manual because I both the machine brand new email me your number
Jun 17, 2013 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
I hit a hidden log with the blade and it threw the belt. I replace the belt; however, now when I engage the PTO the engine dies.
Your log did more than throw the belt. Something is not able to turn, so when you engage the PTO, the blades stop the motor. Look for another belt jammed, or a bent spindle or piece of log jammed under the deck.
May 09, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Unable to find the Troybilt deck V belt that fits my 2002
If it's the belt that just runs on the deck and not the one that goes to the engine, it is a 954-0349
Jun 24, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Stanley 54ZS 726cc 24 HP Gas 54-in Zero Turn Commercial-Duty Riding Mower Logo
41 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
