My Crosley CR49-TA won't revolve. It turns on, and
My Crosley CR49-TA won't revolve. It turns on, and when I turn it to 33 1/3, 45, or 78 I can hear something but the table won't turn. The noise in the video is the noise the record player is making.
    Problem Solver:
  • 7 Answers
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Posted on Apr 27, 2013
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
freetek
  • 5568 Answers
SOURCE: new crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Posted on Aug 15, 2009
lesliemurphy
  • 69 Answers
SOURCE: turn table wont spin.
if its a direct drive turntable then the motor is under the spindle as the spindle is a composite part of the actual motor? Its most likely burnt out i`m afraid? sorry
Posted on Sep 15, 2009
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
Crosley turntable CR49
Check if it is still covered under the manufactures warranty, you might be able to send it in and have it fixed. Although, I am not sure if they would ship it back to Dubai. Contact customer support and ask them what are your options.
Tech Support: http://www.crosleyradio.com/supportreq.aspx
Warrenty registration: http://www.crosleyradio.com/wreg.aspx
Nov 25, 2012 | Audio Players & Recorders
The table won't turn. I have power and can hear the motor, but no turning. Read other suggestion on removing the plate to check the belt, but i can't get mine off.
Don,t try, You will just damage it, Take it in for repair,Where they no what there doing. If you damage it then it will be verry costly to have it repaired,
Nov 09, 2012 | Crosley CR49-TW Tweed Traveler Turntable...
The turntable is not revolving at the correct speed slowing the record down
Sounds to me like your belt is streched. Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Crosley CR49-TW Tweed Traveler Turntable...
Turntable wont turn
Lift platter and refit belt. Styluscity@gmail.com
Dec 12, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley CR49 Turntable Speed Problem
Do you know how to make a measurement? open your equipment, use your voltmeter to see how much voltage run the motor and then compare with the voltage who is written in the motor. If the voltage which your have read is in the range of motor voltage +- 10% is ok, of no, that voltage must be more than that correct that problem.
If the voltage is the range of motor voltage the replace the motor.
Thank you.
Tell me if this helped you
Mar 03, 2008 | Crosley CR49-TW Tweed Traveler Turntable...
Stopped Turning
I had a similar problem, what I ended up doing is taking it apart and jiggling the wires, the motor runs now, but when i opened it up, the belt was losely laying there, how do i put the belt back on? thanks.
Dec 13, 2007 | Crosley CR49 Shelf System
AC adaptor cord
Try a Radio Shack universal replacement power supply like 273-1773 or 273-1776 or 273-1667 with the proper "Adaptaplug" that goes with it. It should do nicely and be sure to observer the proper polarity of the plug so that it will match your unit. Good luck.
Feb 03, 2007 | Crosley CR49 Shelf System
1,519 people viewed this question
 Grubhead
Grubhead
