Question about Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
Poor washing The soap door opens but soap still in there after wash cycle. We got lower spray arm off and one plastic piece but can't get all the way to the pump. Pump appears to possibly be cracked so we suspect it needs replacing, but we can't get it out.
    Novelist:
  • 159 Answers
Before you suspect the pump and motor assy, do you hang the silverware basket on the front side of the lower rack or if not did one of the holders for the rack fall off and you replaced it? I have found that id the basket is hung on the rack that tall utensils will hold the door from opening fully. when that happens water from the spray arm will not hit the soap dish and when you open the door you will see soap in it. also there is a plastic peice on the top rack if not installed the correct way it wil hold the dispensor door closed causing the soap to stay. I see this problem all the time. when in the wash cycle do you hear the water spraying around inside? If you do I would not suspect the pump and motor. And with whirlpool the pump and motor is a full assembly and it is disconected from the under side of the washer and removed from the top. also run it empty on a short wash cycle and listen for the dispensor door to pop open. make sure thats working properly to. check all that out and let me know if it helped. good luck
Posted on Aug 06, 2007
SOURCE:
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
Soap remains on the dishes after the wash cycle is complete.
Check that the holes in the spray arms haven't blocked up and the filters in the bottom are clean. The arms may not be rotating. To check this, when the machine is washing, open the door, turn all the spray arms to face the same direction, shut the door and leave running for about 30 seconds. Open the door again and look at the position of the spray arms. They should have moved.
Nov 25, 2013 | Samsung DMT400RHS Builtin Dishwasher
When dishwasher is washing and rinsing, water comes out from under the machine and goes all over the floor.
Hello
Look for leaks around the lower spray arm or soap door. Check the plastic on the lower spray arm to make sure it is not cracking down the middle. Replace the arm if you find any cracks or splits. If the soap door is leaking, it probably needs a replacement gasket.
Aug 20, 2011 | Hotpoint 24 in. HDA2000Z Built-in...
GLD6500 Series Dishwasher -- soap dispenser has
Yes that's normal for that machine. The soap has to be washed out of the soap drawer by the top spray arm turning, and that's usually the problem - the arm isn't turning. Check both spray arms for blocked jets at the very end - remove blockages with a pin and water flow from tap. In the worst case, you may need a new spray arm - but they are usually cheap.
More points to remember - on a rapid 30 minute wash program only, if you are using wash tablets, don't put them in the soap drawer as there wont be enough time for them to dissolve. put the tabs in the cutlery basket. Also - a dishwasher is not a garbage disposal unit, and uneaten food must be scraped of plates before putting them in the dishwasher. Run a dishwasher cleaner through now and then, or do a full program wash with nothing in the machine to clean it out and to keep spray arms clear.
Feb 02, 2018 | GE 24 in. GLD6500L Built-in Dishwasher
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Water enters dishwasher, soap door opens but soap
That's a normal path for the soap. It sounds like the water just sits in the bottom without being pumped through the spray arms. Does the pump motor run? Pop the door open in the middle of the washing cycle--you should see hot water dripping from everything and the soap picked up and circulated with the water. If this machine has seen a lot of use, the intake screen under the lower spray arm may be plugged and is accessed by removing the spray arm and working your way down to the bottom of the deck. Might be a problem for a service technician to take care of.
Jul 19, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Soap still in dispenser even though the dispenser door had opened
Be sure that nothing on the top rack is interesting with the door opening. Next place in unit in the wash mode. Let it fill and start washing. Open door and you should have water standing just below the lip on the wall of the unit below the lower rack. If so you are full of water.
Next is to ensure your washer rotating arms are not plugged. The very end of the upper and lower arms spray on the door to wash the soap out. If the are contaminated you will have to remove them and clean the out.
Lastly, the dispenser is operated by what is called a WaxMotor. Simply put it is a small amount of wax contained in a tube with a piston inserted. There is then a heating element around the tube. When it appmys heat the wax expands and pushes on the piston which I turn releases the door to be opened by its spring.
These can go bad and open too late in the machines cycles. It is located in the door and unless you are quite handy I would recommend a qualified technician.
Jan 01, 2018 | Maytag 24 in. PDC3600A Built-in Dishwasher
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher Logo
165 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Bruce Denton
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
