Question about Brother HL-5470DW Laser Printer W/ Wireless Networking & Duplex
Changed drum now black line printing along edge paper L/side
We changed to a new drum and now on the left side of paper a dark line is appearing ... cannot locate any damage on the drum ... the printing is good ... just has this black line on left edge of paper, about 1/4 inch wide.
SOURCE: Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Posted on Nov 20, 2008
SOURCE: Print Problem - vertical lines
I have MFC 7820N. Noticed same problem as other when making copies. Vertical line used to appear.
Open the Scanner where you can see the glass - Flatbed ( where you put the documents to copy)
Make sure that Glass is Clean.
Now make there is Glass on left side about 1x9 inch. Make sure this glass is clean. I had rubbery stain on that I had to rub it off.
Vertical line does not appear when I make copy from Feeder or Flatbed.
Posted on Dec 15, 2008
  • 4 Answers
SOURCE: Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
Posted on Mar 16, 2009
SOURCE: black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Posted on May 15, 2009
  • 133 Answers
SOURCE: Brother MFC 7420: After changing the toner
Just need to clean up all glasses with alcohol and move the blue panel to clean the drum, after that sould be fine.
Posted on May 22, 2009
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Have black lines on left side of paper after printing
Usually this is occurs when the drum needs to be changed.
Jun 05, 2012 | Dell 3100cn Laser Printer
The printer is printing dark along side the edges of the paper each time I print. I've changed the drum, but that didn't seem to help. What else can I do?
Print an empty word document, and if it still shows the dark lines on the edges the rollers are most likely caked with ink, and they will need to be cleaned.
Jun 09, 2011 | Konica Minolta Magicolor 2530 DL Laser...
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Brother HL-5470DW Laser Printer W/ Wireless Networking & Duplex Logo
70 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
