Question about Compaq iPAQ MP1410 Multimedia Projector
They screen isflickering and randomly turning off and some static showing
  • 25 Answers
How old is the unit? If it's a few years old, you might have some failing electrolytic capacitors in the power supply and/or ballast circuit. Usually a visual inspection is all that's needed. Just look for capacitors that are 'swollen,' or have goop either oozing from the top, or leaking from the bottom.
Posted on May 01, 2013
Why is our projection tv getting dots on the screen
If it's random, then it's interference on the signal - if it's static, you may have 'burnt' areas on the luminance
Jul 12, 2014 | Chief Manufacturing Televison & Video
Screen flickering with lines and static.
I would install Windows and see what happens.
Mar 06, 2014 | Acer Aspire 4720 Notebook
My dell inspiron mini 10 is making a random static noise
Muting does not mean turning off the speaker which means there can be occasionel static.
It occurs more if the is a magnet near!!
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
Everytime I turn my PS3 on it gets past the sony entertainment screen the it gets to my background and freezes in a weird way (it has these small multi-colored rectangles come over my screen in a random...
It sounds like you hard drive is starting to crash. Try your HD in a different PS3 and see if it does the same thing. The HD in a PS3 is the same thing that is in a laptop computer and they go bad just like the laptops do.
Aug 02, 2009 | Video Game Consoles & Games
Synaptics touchpad not working properly
Hmm give this method a try. Turn off computer remove AC power adapter. Remove the battery and press the power button for 30 seconds continuously. This removes the static from the system. This process is called as Power drain. This works in most of the cases. Good Luck !!!
Jun 04, 2009 | HP Compaq Presario F750US
Screen shows staticy image on all components
Bad capacitors on the FMT pwb is what is most likely causeing it are the lines going sideways acrooss the screen, yet the menu appears normal.? If so its bad capacitors. You can get the V26 FMT repair kit at the following link which has the replacement capacitors and instructions on how to do the repair. You may also have an issue with the terminal 1 and terminal 2 pwb in that model as virtually every board within the chassis is plauged with Capacitors that fail. Heres the link.
http://servicemanuals.vstore.ca/
Jan 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When I turn on the TV the screen has static
Static usually means that the tuner is not working. Chack all of your cable connections first. As a quick test of the tuner itself, remove the cable from the exterior antenna connection and insert a small paper clip. That will act like an antenna and if you scan for channels, something should be seen. If not, then you probably have a bad tuner or have lost the source power for the tuner.
Dan
May 07, 2008 | Toshiba 50H81 50" Rear Projection...
MY E815 screen has weird signs
Check this link to see info about your phone.
Apr 25, 2008 | Motorola Mobility E815
Screen 1/2 black with random caption in middle side
CHANGE CAPTIONS SETTING YOU HAVE IT ON TEXT1 TURN OFF THIS SETTING. IN YOUR SETUP MENU
Aug 16, 2007 | Sanyo DS24205 24" TV
Compaq iPAQ MP1410 Multimedia Projector Logo
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
