No video when pc is turned on. Monitor says no signal. I disconnected hard drive and I and finally got the motherboard specs on the monitor. Hooked hd back and finally booted but started to reboot every 3 seconds. Now it's doing the same thing where it won't load and no video. Unhooked hd again and got the same mb specs screen again. Any ideas?
  • Computers & ... Master
  • 5,660 Answers
Yeah
Reboot every 3 seconds?
Sounds like a problem with Electrolytic Capacitors, on the motherboard. (Or in the Power Supply)
(Radial Aluminum Electrolytic Capacitors to be more specific)
Capacitors are used as Filters, and Voltage Regulators; on the motherboard. (Electrolytic or Solid Polymer)
The one's used as Voltage Regulators are in the Motherboard Voltage Regulator Circuit.
Part of what the motherboard voltage regulator circuit does, is to regulate voltage for the Processor (CPU)
The Processor MUST have a steady, 'clean', supply of Voltage; and it MUST be kept within the tight voltage tolerance range, for the Processor.
Too little voltage, or too much voltage, and the Processor turns off. (BIOS turns it off)
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://www.hardwaresecrets.com/article/616
http://www.hardwaresecrets.com/article/595
http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
[FOLLOW Anti-Static Procedures!]
Otherwise the problem is the Power Supply.
Yep. Same Ol' Electrolytic Capacitors, are USUALLY the problem.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 26, 2013
  • 12 Answers
SOURCE: i have a pentuim 3 board
try cleaning the gold tipped edges of the processor with alcohol wipes and slot(with a brush) see if that help`s
Posted on Dec 22, 2008
SOURCE: My Pc wont boot no signal in my monitor Help!
hi there..in mobo with platform p35 works the same like that on-off and on again,its normal so dont worry about that
the real problem is screen blank,i've got replaced new mobo with the same type,but the problem still the same.so its not the mobo problem i think.
Posted on Mar 29, 2009
kamal1984
  • 1383 Answers
SOURCE: No Signal To my Monitor and no beep.
First refix the RAM and Pci graphic card.
Pull cmos cell from mother bord for 15 minutes then put again into its position then all settings are defaults.
Then if still face problem then check with other RAM.
Posted on Aug 13, 2009
Testimonial: "kamal is the man!!"
  • 81 Answers
SOURCE: ASUS P4P2E-X 1 long beep that continue without end
hi,
I think One long beep that continue means RAM problem , Ram Can May be dead or faulty, check on other ram.
I hope that this has been very helpful for you
Posted on Nov 16, 2009
  • 8 Answers
SOURCE: instaling video driver problems
it is probably your motherboards built in video driver is your problem..
i suggest you return that motherboard and choose
the same model..
if you can't return it, then i think you need to use the AGP video slot..
Posted on Dec 01, 2009
Monitor is saying no rgb signal its hooked up to tv
Depending on if you have a video card and not the onboard video see if you do and change the cable on the computer to the proper one sending out the signal.
Mar 14, 2014 | Compaq Presario Desktop / AMD Sempron...
How to troubleshoot my my benq t52wa that shows no signal detected
If the monitor is showing you a "no signal" message, it's almost certainly working fine. There's no video coming in from the computer, and that's likely where the problem is. Try another monitor first. It's possible yours isn't recognizing the input signal, but it's unlikely. I've only seen that happen twice I can remember. Chances are that another monitor will say "no signal" as well. Either the computer isn't starting up, or the video isn't working.
If you hear all the sounds of a normal startup (usually a single beep when the motherboard finishes power-on tests, hard drive activity shown by the front panel indicator, and finally the Windows startup sound through your speakers), then the video circuitry is bad. If the video is integrated onto the motherboard, you can install a replacement video card in an open expansion slot. If you already have a separate video card you can replace it.
If the computer isn't starting, you need to suspect memory, the motherboard, power supply or processor. You might also have a bad hard drive, optical drive or other device connected which is preventing startup. Begin by unplugging everything except the main parts: memory, processor and fan, power supply and (if used) video card. If the system starts up, you can identify the bad part by reconnecting them one at a time until the problem comes back. If the system still doesn't start with the minimum hardware, part substitution is how you'll figure out which is responsible.
It can be frustrating, but you'll get the thing going. Good luck, and thanks for using Fixya!
Oct 08, 2010 | BenQ FP737S-D 17" LCD Monitor
I have an emachine cpu and it comes on but my monitor is just black it wont boot and yes the monitor does work can n e 1 give me sum advice please!!!!
Since you know the monitor works, I would go ahead and with the power off, unseat and reseat the memory one stick at a time in each slot one at a time. Try turning on the computer after each memory reseat. This way your testing each slot and each memory stick. Take a can of air and blow it in the slots of the memory so that way the slots are free of dust and debris.
If the memory isn't the issue, then go ahead and unseat and reseat the CPU. Like with the memory make sure there is no dust or dirt in the area by using canned air.
If reseating the CPU doesn't fix the issue then go ahead and disconnect the power to everything inside of that computer. Only make sure the connector to the motherboard is hooked up. If you finally get video when you turn back on the computer then at that point, hook up one device at a time, like the hard drive first, then the dvd drive, etc. Do this with the power off and then turn it on as you hook up each device again and as long as you get video each time then that means a device wasn't hooked up all the way properly.
If you dont get video after only hooking up the power supply to the motherboard and turning it on, then that means the motheboard is bad and would need to be replaced.
May 26, 2010 | E-Machines T2682 (000002965) PC Desktop
Hi, my Dell Vostro 200 monitor isn't working; when I boot up the light is blue and everything else seems to work but the monitor says 'Entering power save mode' or something and it shuts off. I can't get...
Your monitor is most likely fine. That message is the monitor telling you it's not getting any video signal from the computer.
If you're hearing all the sounds that go with a normal startup (usually a beep from the motherboard, then hard drive activity, finally the normal Windows startup sound through the speakers), and seeing that message, then you may have a monitor problem. You can try another monitor as a test.
The trouble is probably that the computer is turning on, but not actually starting up. This may be due to power supply, memory, processor or motherboard problems. Or one of the drives or expansion cards connected to the motherboard may be keeping the system from starting.
Make sure the memory modules are firmly seated in their sockets, and disconnect everything else but the power supply. If the motherboard, processor and memory are working, the system will start and you'll see something on the monitor. Then you can start reconnecting parts and see when the problem returns.
Mar 30, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Nov 04, 2009 | Acer Aspire m5640 PC Desktop
Installing new hard drive and monitor says
Turn the computer off.
Disconnect all the disk-drives, both "data" and "power" cables.
Disconnect the CD/DVD drives, both "data" and "power" cables.
Disconnect the 3.5" diskette drive, both "data" and "power" cables.
Turn the computer on.
Better? Worse?
Nov 01, 2009 | MSI K8N NEO2-F NFORCE3 250 ULTRA S-939 ATX...
I have no signal to my monitor. The asus motherboard is now unavailable. It means changing motherboard, processor and memory. is it worth it? Can I salvage my hard drive if I buy a new tower system...
If you have no signal to your monitor, ther are generally three parts that can cause this: the monitor, the DVI/VGA cable (from PC to monitor) or the graphics card. If I were you I'd try to replace those first, then the motherboard. I'm sure there still are socket 939 motherboards out there, so you will not have to replace memory or processor. Just let someone at a local computer store take it apart, install the hardware on a new motherboard, put the harddisk in the system and reinstall Windows.
(the latter because drivers for the old motherboard may conflict with the new ones. If you don't have any problems with that, don't)
I hope this helps,
Yannick.
Oct 15, 2009 | ASUS A8N-VM Motherboard
When I turn on my pc I an see the hard drive light working and flashing, indicating that it is loading up, but my monitor does not receive any video signal,so I hooked my pc to my freinds monitor and I got...
Sounds like your video card is bad. You will need to purchase a new one. On some machines there is 2 video connectors -like 1 on the motherboard and 1 other mounted in a slot just verify that you have tried both connectors if you have them before buying a new card.
NOTE: Usually the slot mounted video card will over-ride the motherboard video by default.
Good Luck!
Rich
Jan 30, 2009 | E-Machines eMachines Desktop PC
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
