Question about Dewalt Dc390 18v Cordless Circular Saw, 2 Dc9096 Batteries, Charger Xrp 18 Volt
Dewalt dc390 trigger wiring
Wiring trigger
5 Suggested Answers
  • 25 Answers
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Posted on Apr 18, 2009
brewerstool
  • 141 Answers
SOURCE: repair spring to lower guard to spring back
You may be able to salvage the torsion spring that is there. Sometimes the end will break off and you can bend yourself a new end and just stick it back into the retaining hole in the housing or guard. There may be damage to the guard which will not allow you to just bend the spring to make a new joint. Either way, you need to know what you are dealing with. First remove the blade if you haven't done so already. Then remove the bumper (rubber piece) that stops the guard from returning too far. Next you will need a pick or a small flat head screwdriver. Look around the hub and you will notice a retaining ring. You will have to use the pick or screwdriver to get the ring started. Look for a little tab around the perimeter of the hub. You will have to work that tab out and make sure you keep your pick or screwdriver under it. Then work it around and off the hub. Then you can remove the guard from the hub. The spring is located under the guard and is a torsion spring. Look for damage to the guard and the housing as well as the spring. If there is any question to the integrity of the guard you should replace it. The part number for the torsion spring is 612517-00 ($1.50), the retaining ring is 150383-00 ($1.50) just in case you break it, and the guard number is 611925-00 ($6). If you have any questions please post back.
Posted on Oct 28, 2009
kel1guy2002
  • 3740 Answers
SOURCE: i have just brought a
It is possible that the motor is running backward but... first see the manual here:
http://www.plumbersurplus.com/pdf/08364.pdf Make sure the blade is installed as pictured in figure 4 page 11 of the manual.
After seeing the manual..... make sure the battery is charged correctly. The flat side of the battery should be toward the back of the charger when charging. If somehow the battery was inserted backward in the charger it is possible the battery was reverse charged during the intital charge. If you suspect this has happened.... insert the battery in the saw and run the saw until the battery is DEAD. Then insert it properly in the charger and leave it there for 9 hours so the charger will do the automatic tune up equalization of the battery.
If none of the above correct the problem, someone connected the internal battery power wiring incorrectly during FACTORY assembly. I would take it back to the retailer first... before processing a warranty claim.
You can contact DEWALT here:
call 1-800-4-DEWALT
(1-800-433-9258).
Thanks for choosing FixYa,
Kelly
Posted on Apr 30, 2011
  • 885 Answers
SOURCE: user manuel for dewalt dc390 battery powered skillsaw
Go to http://servicenet.dewalt.com/Home, put your model number in the 'Find Parts' box and hit search. There are two types of your saw, DC390B and DC390K, select the proper one and you can view or download the parts breakdown or instruction manual.
Posted on Dec 29, 2011
How do i change the brushes on a DC390 circular saw?
https://images-na.ssl-images-amazon.com/images/G/01/th/aplus/dewalt/dewalt-DC390B-main-sm.jpg take down the black cover in the end of motor. and there will be brushes. take out old ones. mesure them wide and height. buy new one's. add to the place and have working thing ;)
Nov 24, 2015 | Dewalt Dc390 18v Cordless Circular Saw, 2...
How do I put the dewalt dc390 back in the case?
Have you tried to remove the battery and put it in separately?
Sep 21, 2014 | Dewalt DC390K 18v Cordless Circular Saw...
I have dewalt 18 v circular saw i cut vinyl lattice once and used it on a 2x4 but it wouldnt cut it, started to cut then just stopped. is blade dull already? new saw.
a couple things to look at. Did the saw stop operating or was the blade not wanting to cut. Remove the battery and CAREFULLY feel the blade for dull or broken segments. If the blalde stopped check to make sure not a loose bolt holding it on. Did you reverse the blade for cutting the vinyl. Let me know more information and I will try and help
Feb 02, 2012 | Dewalt 18 V Cordless Circular Saw Model...
User manuel for dewalt dc390 battery powered skillsaw
Dec 29, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
I have just brought a new dewalt dc390 cordless circular saw and it seems that the motor is running backwards?
call 1-800-4-DEWALT
(1-800-433-9258).
Kelly
Apr 30, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
How do you know if the trigger is bad? getting dc volts to trigger but nothing out when I press it.
It's not unusual for Dewalt triggers to go bad and it appears you have correctly tested the trigger. You can test the motor by wiring it directly to the battery but hold on to it and only give it a short burst of power so it doesn't spin out of the case. Dewalt triggers are fairly easy to find online but shop around, they're not cheap.
Jan 26, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
D25600 does nothing when i pull the trigger
take it to a repair shop.could be broken wire in lead,could be burnt out armature,could be crook trigger switch,try a new plug on the lead
Jul 05, 2010 | Dewalt D25600K Electric Rotary Hammer
Can't remove the old blade, which way do you turn the nut?
set the blade lock or use a pair of vise grips securely fastened to the blade and turn the bolts counter clockwise
Jan 21, 2010 | Dewalt 18 V Cordless Circular Saw Model...
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Dewalt Dc390 18v Cordless Circular Saw, 2 Dc9096 Batteries, Charger Xrp 18 Volt Logo
43 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
