How to reset control panel to $1.50 / $2.00 on a Maytag commercial washer
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jul 15, 2013
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: control panel locked
The following link explains how to correct a Control Lock problem for your washer:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
I know this link is for Kenmore Elite and Whirlpool Duet. The newer model Maytags are manufactured by Whirlpool (which also makes the Kenmore Elite) so these instructions should apply. Keep in mind control panel options between models may differ slightly, but the locking feature instructions should be printed on the front panel. If you are not sure, there should be a tech sheet inside the washer behind the lower kick panel under the door. If not directly behind the panel, the sheet should be affixed to one of the interior cabinet walls.
If these preliminary measures do not correct the problem, you may have a more serious problem. If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: The Control Lock feature is a built in safety feature that allows you to lock the front panel to keep small children from manipulating the controls.
Posted on Aug 14, 2009
SOURCE: Program computer-Maytag commercial washer mat12pdbaw
Try going to this website and scrolling down to find your Maytag Model number. Click on the model number and the programming steps should come up for you.
Anonymous
Posted on Feb 23, 2011
SOURCE: maytag centennial commercial technology washer, having intermittent trouble with controls, wondering how to acess controls to clean connections ?
There are two 1/4 inch hex screws on the back of the control panel and a pair of metal tabs at the base that hold the panel assembly together. I found this video on youtube that illustrates how to take the assembly apart.http://www.youtube.com/watch?v=7yxjNiAKvYwI fixed mine by just cleaning the contacts on the auto load sensing switch.
Posted on Nov 14, 2011
How do I reset/clear error codes F20 and F21 on my Maytag commercial washers?
Try to turn off power for 2 minutes and fool the washer into thinking it is new vs suffering a water loss. If that doesn't work see if there is a reset button on the mother board.
May 16, 2016 | Maytag Washing Machines
Maytag centennial commercial technology washer, having intermittent trouble with controls, wondering how to acess controls to clean connections ?
Nov 12, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
My dog locked the control panel on my epic maytag washer
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Service Manual
Apr 04, 2011 | Maytag Washing Machines
Need to reset price for washer and dryer
if its not working board might be bad
May 18, 2009 | Maytag Washing Machines
Commercial Energy Advantage High-Efficiency Front-Load Washer MAH22PRAWW
Take the front panel off, (12) screws in all. Start by the soap drawer (2 t-20's {safty type}). Then loosen the 4 T20's (also safty type) that hold on the aluminum face plate & display lens. Now the front meatl cover can come off (there is a snap clip by the soap drawer). Now remove the 6 - 1/4" inch screws 2- hold the top down, the other 4 hold the control board on. Now remove the control board & turn it over. You will see a white 3 pole connector plug, by it on the board it will say " service & coin". Remove the plug, now look at the display & you will see the error code. It will either be a "D" or an "F" code depending on your setup. Now push the lower left button on the panel (Delicates & Knits). your display should read 600 or 6 and a couple #'s (this is coin count). Replace the plug & your reset. Now just put it back together. Remember the display lens has a small window that need's to go bact into the upper left corner. I'll bet it will be an F22 or D17 - either way be carefull about closing the door (make sure nothing is caught by the door and boot seal). D8 or F21 -means long drain watch how much soap you use 1/4 cup or less is best. I hope this helps you.
P.S. keep track of the error codes- Maytag/Whirlpool may owe you an upgrade on the machines software.
Sep 21, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag vaccuum line, drain washer and reset
This is not so difficult as it looks
turn off the taps
unplug the washer
open the back of the control panel
pull off the pressure line
blow in it till bubbles are heard in the tank, the line is now empty you dont have to blow very hard
cap the line with your thumb
quickly reattach the line to the level sensor without letting air escape
close the panel
plug in
pressure sensing will be correct if no air escaped
Sep 11, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
