Question about APC Matrix-UPS 5000 UPS System
Batt are 100% chared "showbon LCD) but its shows low batt. when start backup
    Top Expert:
  • APC Master
  • 44,580 Answers
Replace the battery.
Posted on Apr 26, 2013
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
Tip
How to backup and monitor a desktop computer
<p>The computer systems are based on the memory and storing information. However, as the crash of a computer system, causing loss of data, all previously stored information. All computer systems, servers and personal computers, users can backup storage disks to store and to store information - in case of system failure. Creating a backup system is completely dependent on the operating system on the computer. <br /> <p><br /> <p>1. Press Start. Select "Control Panel". <br /> <p><br /> <p>2. Connect your external hard drive on the computer begin transmitting and storing files on your external hard drive. <br /> <p><br /> <p>3. Click on "maintenance". Choose Save and Restore. " <br /> <p><br /> <p>4. Choose your external hard drive and choose "Configure a backup." A wizard will appear and give you further instructions. While the setup wizard, you can schedule backups, and select where your backup files to save. Under Windows, the recommended storage for backing up files and programs on an external hard drive. <br /> <p><br /> <p>5. Show your stored files by choosing "System and Maintenance" and select "Backup and Restore". On the menu, select "Find files" or "Search" folder to the contents of your backup view. Because Windows will automatically create backup files when it is supplied, you can check or change the scheduled backup for "Schedule backup" to monitor the dates and times for the safety of a system. <br />
on Jun 22, 2011 | Computers & Internet
Surt10000xli not switching on
my ups surt10000xli ups shows internal faulty LED On, i have checked main board but couldn't find the fault. please tel me the fault
Feb 15, 2011 | APC SURT1000XLI 1000VA 700W 230V UPS...
Battery backup is too low..
This may happens sometime with charger ,as i have the same problem and i replace the charger---i shown the mbile HTC authorised center
Aug 05, 2009 | HTC Touch P3450 Smartphone
Charge for ipaq 3417 does not show up on NIMH battery
sounds like u may have inadvertantly nudged/disconnected the backup battery
(CMOS type) while u had the unit apart
pics of the batt are available on youtube or ebay.
Jun 13, 2009 | HP iPAQ RX3115 Pocket PC
IPaq rx3115 working like PC not Pocket PC, need to plugin always
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
Hope this helps
Jun 01, 2009 | HP iPAQ RX3115 Pocket PC
When I turn the camera on the following message appears- high camera temperature, camera will shut off. The camera is a Kodak easyShare Z710
Have Kodak Easyshare V1253 with same, "high temp.," error then shutdown. Kodak batt. showed 25% charged. Charged batt 100% & temp. error went away. Batt. internal shows camera if batt. too hot. Try new batt.
Sep 12, 2008 | Cameras
APC Matrix-UPS 5000 UPS System Logo
83 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
