Sharp el 510r
How do i plug in quadratic formula
  • 7993 Answers
SOURCE: how do I use sharp EL 531W to solve quadratic equations?
This calculator does not have a program to which you give the equation, and which returns the solutions. Sorry. You have to use the formulas you learned.
Let the equation be ax^2 +bx+c=0
You compute the discriminant Callit disc.
disc= (b^2-4*a*c)
1. If discriminant is larger than zero you have two solutions. Let us call them x1 and x2.
Then x1=(-b+square root of disc)/(2*a)
and x2= (-b-square root of disc)/(2*a)
2. If disc=0 , square root of disc =0 and x1=x2=-b/(2*a)
3. If disc is negative, there are no real solutions.
To find the solutions you replace a, b, and c by their numerical values, to calculate disc, its square root, and calculate X1 and X2.
Hope it helps.
Posted on Sep 17, 2009
  • 7993 Answers
SOURCE: how to solve quadratic equation in SHARP EL-531WH
You compute the discriminant Call it disc.
disc= (b^2-4*a*c)
Hope it helps.
  • 7993 Answers
SOURCE: How do I use sharp EL W531 to solve quadratic
disc= (b^2-4*a*c)
Hope it helps.
  • 7993 Answers
SOURCE: how to solve a quadratic formula using a casio
The calculator does not have a solve program, but you can still use it to solve the quadratic equation with a little effort. If you know the therory skip toward the end.
Let aX^2+bX+C=0
1. First calculate the discriminant usually called Delta and given by
Delta =b^2 -4*a*c store the value in the variable D
If Delta is positive you have two roots X1 and X2 given by
X1=(-b+square root of Delta)/(2*a)
X2=(-b- square root of Delta)/(2*a)
If Delta is equal to 0, X1=X2=-b/(2*a)
If Delta i negative, no real solutions exist
You only solve if Delta is positive or equal to 0.
Putting in the values of a, b, and c
value of a (put you number) [SHIFT][STO] A
value of b (put your value) [SHIFT][STO] B
value of c (put you value) [SHIF][STO] C
[ALPHA] B [X^2] -4[x][ALPHA] A [x][ALPHA] C [=]
Value of delta is displayed. If it is positive, you store its square root in D
[Square root] [ANS] [SHIFT][STO] D ;
Calculate 1/(2*a) and store in variable F
1./(2[x] ALPHA A) [SHIFT][STO] F
To obtain X1
[ALPHA] F [x] ( (-) ALPHA B + ALPHA D ) [=]
To obtain X2
[ALPHA] F [x] ( (-) ALPHA B - ALPHA D ) [=]
Be careful: the (-) is the change sign not the regular minus sign.
Hope it helps.
Posted on Sep 24, 2009
  • 7993 Answers
SOURCE: How to program the calculator TI-nspire to solve
Whay would you want to go through the hassle of writing a program to solve to solve a quadratic equation`The calculator has two buit-in command to do just that. It has Solve and cSolve (for complex solutions).
Open a calculator sheet, and on the command line, type in solve(ax^2+bx+c=0, x), press ENTER and wait for the solutions
Posted on May 11, 2011
How am i supposed to solve a quadratic equation ?
Use the quadratic formula, or factor the quadratic polynomial. Once factored into a product of two first degree binomials, the roots are obtained by setting (in TURN) each binomial factor equal to zero.
May 02, 2014 | Casio fx-300ES Calculator
How to solve quadratic equations on fx82ms calculator
You can do it the same way people did it before calculators were invented. Just use the quadratic formula: http://en.wikipedia.org/wiki/Quadratic_formula. Some sophisticated calculators have generalized equation solvers that can handle equations much more complicated than the quadratic, but the fx-82 isn't one of them.
Nov 06, 2013 | Casio FX82MS Scientific Calculator
How can i solve quadratic equation (aX^2+bX+c=0) with my BA II plus texas instrument calculator?
The BAIIPlus doesn't have anything specifically for solving quadratic equations. You can simply plug the coefficients a, b, and c into the quadratic formula.
Oct 03, 2013 | Texas Instruments Office Equipment &...
How do I solve quadratics on my 531x Sharp calculator?
There is some confusion here.
In stat mode [Quad] the calculator tries to fit a quadratic function to your (already entered) data. It gives you the coefficients a, b, and c of the 2nd degree polynomial that best describes the data.
To solve an equation you need to use the solver not statistics.
Jun 11, 2013 | Sharp el-531x scientific calculator
How do you calculate expected value on the sharp el 520w
Set up the correct formula on paper and follow it. Use parentheses to avoid ambiguities.
May 18, 2012 | Sharp EL-520WBBK Calculator
How do you do quadratic equation
If your equation is ax^2 + bx + c = 0 then the quadratic equation is 3ea647783b5121989cd87ca3bb558916.png. Just plug the corresponding numbers into the formula and you will get the answers.
May 11, 2011 | Sharp ELW535 Calculator
How to program the calculator TI-nspire to solve the quadratic formula
May 10, 2011 | Texas Instruments TI-Nspire Graphic...
How do I use sharp EL W531 to solve quadratic equations?
disc= (b^2-4*a*c)
Hope it helps.
Jun 26, 2009 | Sharp EL-531VB Calculator
How do I use sharp EL 531W to solve quadratic equations?
disc= (b^2-4*a*c)
Hope it helps.
May 17, 2009 | Sharp EL-531VB Calculator
How to solve quadratic equation in SHARP EL-531WH
disc= (b^2-4*a*c)
Hope it helps.
May 05, 2009 | Sharp EL-531VB Calculator
193 people viewed this question
jasbo
jasbo
