Power light and lamp light blinking alternatly
Hello all my tv blew the ballast and the bulb. i replaced ballast with new and bulb with jvc replacement, and while i was in there i replaced all fans even the fan under the base unit. was getting an error from tv led codes that indicated the temp sensor so replaced that. but still getting the same error from leds, all fans are running bulb does light up but no display and about a min later the unit shuts off, ballast and temp sensor replaced.....any ideas.
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
Get into its service menu and reset the error buffer. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Posted on Apr 26, 2013
Testimonial: "thank you for your response. unfortunately i do not even get a picture of any kind. i looked through the forum you suggested with no success. all the symptoms happen during power up but before display is given, then get error and unit shuts down about a minute later but all fans are running lamp lights momentarily then lamp goes out and error comes then power of a few moments later. "
TV blue light comes on, then the red light blinks two times, on the 3rd blink, it goes into rapid blinking. I replaced the lamp and it worked for a week, but then the same issue. I put the old lamp back...
some units require a lamp counter reset.the ballast usually starts at extreme output and at certain hour interval the ballast would start to decrease voltage as the bulb ages.to reset on some models can be reset using the remote
Aug 12, 2013 | JVC HD-61Z786 61" Rear Projection HDTV
I installed a new lamp and the tv is still blinking saying the lamp is bad. There is no picture.
its most likely the ballast which is causing the issue. The ballast is what provides the power source to light the lamp. You can get the ballast at www.tvrepairworld.com and they can provide instructions on how to replace the ballast
Mar 31, 2013 | Mitsubishi WD-73733 73" HDTV
Power led and lamp led blink simultaneously on my jvc hd65s998 rear projection tv
You might need to replace your lamp driver, or ballast as some call it. This is what strikes the lamp to make it light.
Mar 20, 2013 | JVC Televison & Video
Lamp turns on lamp light starts blinking then turns off
Check the lamp ballast, it works just like a flourecent light if the ballast is bad it will turn the light off. It comes on a board try searchinng ......ebay or thetvdoctor.comXHRWN5
Feb 23, 2012 | JVC HD-56FB97 HDTV
Power light on jvc av32430 is blinking green
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | JVC AV-32430 32" TV
LAMP light blinking after replacement.
Lamp Fan or Ballast board,problem could lead back to Dmd Module Encompass Parts Distubtion has what you need for this Set 1-800-638-3328
Feb 24, 2010 | Samsung HL-P6163W 61" TV
I just replace the bulb in my JVC HD-52Z575 everything was fine for about 10 days. Now when I turn the TV on it works for about 30 to 45 min before it shuts off, the fan kicks in, and the LED power light...
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
Jan 25, 2010 | JVC HD-52Z575 52" Rear Projection...
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Replaced bulb & tv not working
did yo here the ballast start up also ,it generates the voltage for the uhf bulb,try to lesten foe a small arcing noise from the rear of unit.also make sune you installed the lamp correctly ,seated there are switches that let the set know when the lamp is out of the set,/
Aug 23, 2007 | Sony Grand WEGA KF-50WE620 Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
