Question about Kenmore 23822 Top Load Washer
Does not spin
The loader does not spin
  • 10 more comments
  • Anonymous Nov 17, 2007
    does not spin and stop without taking out the water.
  • Anonymous Dec 08, 2007
    the washer does empty the water out...it just is not spinning...any suggestions?
  • Shabani 007 Dec 19, 2007
    Our Hotpoint top loader fills up with water and drains the water but doesn't spin nor wash the clothes.
    The machine is only 8 years old. We opened the front and there is a white wire that is disconnected, where should it go? It makes a sound, just no movement.
    Please advise.
  • Anonymous Dec 29, 2007
    This is for an amana top loader, washer will fill, and agitate the clothes. but will not spin on any cycle. I checked the belt it is good, I'm assuming the motor is ok since it agitates correctly. It has been sugested that the lid switch could be bad, and I did see in the schematic that it is the same switch that shuts off the machine if the load is out of balance.
    Any suggestions.
    Thank you
  • Anonymous Feb 23, 2008
    MY washer does not spin. I am able to hold the lid button down and the washer will drain the water, BUT NOT SPIN on any cycle.
    Ron
  • Anonymous May 13, 2008
    I INSTALL A COUPLING ASSEMBLY ON A 70 KENMORE WASHER AND I WASH A LOAD OF COLTH AND DURING THE SPIN CYCLE IT STARTED SQUEAKING AND SMELL LIKE BURNT RUBBER BUT IT STOP ON THE SECOND TRY , WHAT COULD IT HAD BEEN TO DO THAT ,PUZZLED ,BIGO FROM CLUTE
  • Anonymous Jun 10, 2008
    have no spin cycle every thing else is fine
  • i10barjay Aug 04, 2008
    how do you take the top off so I can check the lid switch. The plastic part with the spring in it fell completely off. When I stuck my hand under the rim I can feel where it goes, I actually got a little shock, if I could just open the top I could replace this plastic part....
  • lkendrick1 Aug 07, 2008
    how do i rome the agitator so ican get to the spanner nut my skirt is wrapped around it and the washer will not spin kenmore 70
  • stroker52 Aug 26, 2008
    I have a Kenmore Heavy Duty 70 Series, It fills with water but doesnot agitate and doesnot spin out the clothes are still wet but the water has been pump out, you can hear the motor but its not agitateing and the tub doesn't spin out.
  • Anonymous Jan 19, 2009
    My washer does not spin on spin cycle, I have the part but how do I get into the weasher. It has a sold back and I don't have the manual and don't want to breack it.
  • Anonymous Jan 25, 2009
    Top load Kenmore washer Model 100.22702.100 wont spin, found that the lid switch plastic mounting had broken. How do I open the top of the washer so I can replace the switch?
The machine will agitate and pumpout the water but it will not spin
Posted on Nov 18, 2008
Kenmore washer that will not spin and smell like somthing was burt
Posted on Sep 20, 2008
  • 530 Answers
If the washer is making a grinding noise it could be the drive coupler.
Posted on Oct 17, 2007
  • 641 Answers
Does the machin, pumps water out ?
Posted on Aug 06, 2007
I have a GE top load washer Modle # WHDSR209DDWW/Serial #ZL137697G That will not spin or pump out the water.
Posted on May 05, 2009
My was wont spin it will wash but wont spin
Posted on Apr 02, 2009
Model # LNC6762B71 Admiral Top loader Waaashing Machine about 3 yrs old.
Started making a very loud noise when it went into the spin cycle. I had a service company look at it and they checked the belt,Transmission, motor and all checked out fine. They suggest that the top and bottom bearings are worn out.
I am a single lady,living alone, I don't have a large amount of laundry. I don't understand how this is possible.
The Service Company that I have adready paid $91.00 is asking another $290.00 to replace the top and bottom bearings.
ALso, the washer is leaking water after it is turned off. Maybe a Water Valve I was told.
Did I get ripped off when I purchased this washing machine?
Please Help
Posted on Feb 18, 2008
Roper washing machine will not spin
Posted on Jan 17, 2008
Check the lid switch. I had the same problem and the screws holding the lid switch had come loose causing the switch to drop. Because it was so low, the arm on the lid couldn't touch the switch when the washer was closed.
Posted on Sep 05, 2007
    President:
  • 1,294 Answers
Plug off the wall & check your filter, refer to your manual re. this You can also check to see if there is any block in your exit hose. Things like these happen when there is clogging............ If all these dont work, look into your pump.
Posted on Jan 21, 2008
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Feb 24, 2015 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
My machine is not spinning when spin is selected
HI. if this is a belt driven top-loader, or front-loader, more than likely, the belt has slipped off the drive pulley, or the belt has failed. Now, if this is a top loader, with a direct drive assembly. the motor coupler will be the culprit in this case.
Oct 13, 2009 | Washing Machines
The washer runs through entire cycle but when it gets to the spin cycle the motor clicks on but does not spin
Hi there....you havent stated whether its a top loader or a front loader.....top loader 1st.....
usually caused by a defective drive clutch..this will require the drive mechanism to be removed and a relacement clutch fitted
front loader 2nd...this is usually caused by failed spin windings in the motor..worn carbon brushes in the motor.or a failed programmer....
regards Sir Galahad
Aug 16, 2009 | Washing Machines
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 23822 Top Load Washer Logo
1,401 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
