your problem is a part called a clock spring located underneath the steering wheel.best to have a shop replace it for you, special wheel puller is required to remove the steering wheel, this part carries wires for all controls and air bag that are control by the steer wheel buttons.
my honda civic ex 1996 the cruise controle have a trouble when i push (on) the switch on the dash the green light stay off i dont have a cruise controle i need help Thank
check all your fuses first then take a look at the brake switch and there is a criuse cancel switch also, i think there may be a problem with the switch,even if the cancel switch was bad i think the power would still stay on but cruise would just stop and power would stay on. check fuses and switches anyway to be sure then take a look at the power switch.
Check the speed control deactivation switch on the master cylinder. disconnect and use a jumper wire to connect the wires together. If the cruise works it's the switch.
my 1997 honda accord cruise control fuse blow and the car start up but will not go in gear. I change the cruise control fuse the car goes in gear then the fuse blow again. WHAT IS THE MY CAR PROBLEM.
Yes, it probably is the brake switch. It must be working properly for the cruise control to work. If the part you got did not come from a car with cruise control, it will only have two electrical posts and not the four that you need.
If it is the right part, it must be turned in until the button is pushed completely, but not so far that it begins to actuate the master cylinder. Please report your results.
