Question about Kenmore Washing Machines
4174404200 Spinning drum is loud. All of water does not come out
  • Kenmore Master
  • 16,973 Answers
See if there is an access panel under the door or in the back. There should be a drain plug that you can remove. Get ready for a flood! There is a filter in the drain that could have something stuck in it. IF there is not, it could be a bearing going out in the drum.
Posted on Apr 26, 2013
Washer drum making loud noise when spinning
Reach into the drum (on a front-loader)and push upward to see if it moves at all, you should feel no play where the drum support shaft passes through the bearings... The bearings will "roar" loudly during spin if the main seal has leaked water into them... Top-load washers will exhibit the same roaring if the seal fails in them also. Whirlpool Tub Seal and Bearing Kit W10435302
May 13, 2016 | Washing Machines
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
When the washer is spinning it is very loud.
you need to replance the drum bearings and water lip-seal behind the inner drum,it requires you to completely dis-assemble the machinesfront cover,then remove pulley from drum in rear,drum boot seal,then knockout bearings and seal and replace these then re-assemble the machine in reverse order
Jul 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
My LG Front Load Washer is making a horrible, and loud, sound, esp. when it is spinning. Sometimes is also leaks a little too, as I find a puddle of water coming from under it!
Hi dear.According to your explanation,machine's drum bearing gone.That's why it's loud when it's spinning & leaks especially high water level.That needs to be fixed.Please consult service centres get quote & make your decision(It's a costly repair).I hope that helps.Thanks.
Sep 01, 2010 | LG WM1812C Front Load Washer
IT LEAKS WATER AND IT MAKES A REAL LOUD NOISE WHEN IT'S SPINNING..
your drum bearings and tub lip seal are defective,it requires you to remove the rear access panel and the inner drum,then remove bad seal and bearings
Mar 09, 2010 | Washing Machines
One of the water sprays seems to be catching on the top of the drum when it is spinning causing a loud knocking when using the machine
If its drum noise then could be drum bearings gone/ also worth checking concrete weights to make sure not loose causing noise
Nov 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Burning smell, loud when spinning, bleach spots
The bearings that hold the drum on the shaft are faulty, the bearing seal eventually wears out, water gets in, the bearings rust and become loose due to the forces exerted when the machine is spinning. The burning smell is due to the bearings being loose so the drum is off centre (very noisy spin) they rub against the door seal which is rubber, when spinning this causes alot of friction and heat. The spots on the clothes are a common thing, the bearing fluid leaks into the drum causing oily stains, this might look like bleach but it isn't.
A bearing repair job is quite expensive (£80-150) if you can order the spare part bearings you will get the job done cheaper by just paying labour charges.
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
41 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
