Question about Vehicle Parts & Accessories
In need! What is the correct fuel psi for a 2004 f150 4.2L v-6 ?
    Problem Solver:
  • 14 Answers
Should be around 40 psi and rise and
not fall on acceleration.
Posted on Jul 14, 2013
  • Vehicle Part... Master
  • 15,937 Answers
Over 40 psi.
Posted on May 09, 2013
Rough idle low comression #6 cyl
plug, plug wire, coil or igniton module. Check for vacuum leaks.
Dec 10, 2013 | 2004 Ford Ranger
2004 Dodge Stratus 2.4 liter Fuel pressure
Fuel pressure should be around 50 psi +/- 5 psi. So anywhere from 45-55 psi is normal.
Dec 03, 2013 | 2004 Dodge Stratus
What is the correct fuel pressure for a 2004 isuzu 3.5L
Autel Maxidas Ds708 OR Snap On scanner does read the Fuel Rail Pressure,correct pressure is from 50 to 80 psi
Jun 23, 2012 | Isuzu Axiom Cars & Trucks
I want to no the fuel pressure for a 1999 ford explorer
Hello johnnyimsn: My name is Roger and I will help with your question. You did not say what motor was in your Explorer. I will give you the pressure for both. On the v-6 4.0 engine the fuel pressure is 30 to 65 psi with the key on engine off. If you have the 5.0 v-8 engine the correct pressure is 40-65 psi. key on engine off. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Dec 01, 2010 | Ford Explorer Cars & Trucks
What is the fuel pressure spec for a 2004 tahoe with 5.3 flex fuel. I have low power. Changed fuel filter, air filter and oil and still no power. Checked fuel pressure and had about 43 psi. not sure what...
I would change the fuel pressure regulator first, if no change in pressure the fuel pump is on the way out.I have a 01 silverado 4.8 and my fuel pressure is between 55and60 psi.
Feb 22, 2010 | 2003 Chevrolet Tahoe
When doing a fuel pressure test on a 04 trailblazer 6 cyl what is the recommended fuel pressure
4.2 ENGINE FUEL PRESSURE IS 50-57 PSI. 5.3 ENGINE FUEL PRESSURE IS 55 - 62 PSI.THIS IS WITH THE KEY IN THE ON POSITION WITH ENGINE OFF.
Aug 15, 2009 | 2004 Chevrolet TrailBlazer
2000 Chevrolet S10, 4.3, 2wd, 162,000. Surges during take off or under load. New distributor and TPS, MAP 6 months old. Tune up has 40000 miles on it. Fuel pressure 60 psi idle, 70 psi full throttle. Truck...
Sounds to me like fuel delivery issue. If i am correct this engine has the injector unit inside the intake manifold. When the engine needs the extra fuel for accel or loads it just isnt there. You are going to have to do a fuel drop test to determie if the correct amount of fuel is being released for the amount of time the injector is open.
Aug 14, 2009 | 2001 Chevrolet S-10
4.3 Liter V-6 Idles rough when in gear, runs fine on highway.
Can you check fuel trims at idle and under load?
If fuel trim is high at low speed and load, look for a vacuum leak.
If fuel trim is high at high speed and loads, look for fuel volumn problem or restriction.
If fuel trim is high at all speeds and loads look for pcm input fault, maybe a maf sensor problem?
If fuel trim is negative low speed and load, look for fuel pressure regulator or injector leak. If fuel trim is negative at all speeds and loads check ect and iac.
If you have the spider fuel system, that system is noted for problems. key on engine off, 60--66 psi fuel pressure.
Mar 06, 2017 | 1999 Chevrolet Silverado 1500
2004 f350 6.lt diesel wont stay running.
I assume you have checked the oil for proper level? They cant be low or the thing wont start as oil is needed to fire the fuel injectors. Your gone to really have to have a scan tool that can read the oil pressure off the high presure pump. The thing will have to have about 700psi ICP pressure anything less and it will not start. You could still have a HI psi oil leak under one of the valve covers, or at the hi psi pump snap together fitting. If its big enough leak it can cause no start or symptom you are describing. Unfortunatly its complicated to find you need a scan tool, special test fitting so you can air check the hi psi oil system and listen for leaks, it can come from eithe valve cover area or under the hi psi pump.
Jan 21, 2009 | 2004 Ford F350
Vehicle Parts & Accessories Logo
43 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
