Question about Sew D'Lite Lightweight Portable Mechanical Sewing Machine
Trouble shooting my machine was sewing fine one minute and then started getting snagged every few stitches. it appears that the thread gets caught on something behind the bobbin casing. After that the thread and needle get knotted very quickly, even if they dont the stitches are loose and pull out easily. I removed the plate and the bobbin casing to see if there was anything broken or causing the problem, but nothing looked a miss. I did notice that the bobbin casing and bobbin do not clip into their settings, but that could have always been like that. Frustrated... please help
  • R.A. Ellis
    R.A. Ellis Apr 28, 2017
    Remove the bobbin from the machine and thoroughly clean any thread/lint from inside. Also, clean around the feed dogs. Check that the bobbin is wound smoothly and no threads are hanging out anywhere. Rethread the bobbin into the machine.
    Install a brand new needle.
    AVOID old or bargain bin thread.
    Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the top tension at the midway point.
    Re-test your machine.
    If it continues misbehaving, it probably needs service.
  • 288 Answers
Its the tensioner knob turn it a little bit till the stitch is back to the way its suppose\ed to be, don't turn the knob a lot ust a hair a little AT a time try the stitch each time you turn it to see if the stich is tight again. The knob has numbers on it you have to d this in straight stich setting
Posted on Apr 28, 2017
4 Suggested Answers
  • 1952 Answers
SOURCE: bobbin problem
Remove the race cover and jiggle it out. It is only stuck in there with thread.
oil the machine first. Then, determine whether or not you need any parts at all.
Posted on Jun 25, 2009
  • 111 Answers
SOURCE: Bobbin problem
upper threading/tension is wrong
Posted on Jul 08, 2009
  • 18 Answers
SOURCE: Not creating a complete stitch
The needle may be threaded from the wrong side. Newer models thread from front to back of the machine, older models will thread from right to left, It is usually determined by the positions of the needle eye. rethread the top, if this does not correct the problem thne rethread the bobbin, use the instr manual to make sure it is correct.
Posted on Oct 24, 2009
Top thread intermittently goes through middle of bobbin thread
If it does ok for around twenty stitches and then pulls the bottom stitch to the top there is this problem:
1. Top thread has tension added all at one time. This means the thread is getting a snag somewhere.
2. When you thread the top do it with the foot up. As you are threading make constant small tugs to see if there are any snags.
3. When a snag is found it will have to be smoothed for the thread to move smoothly.
4. Check the thread while it is flowing through the needle. If it is getting a puff ball you will need to replace the thread with a quality embroidery thread.
Apr 08, 2015 | Sewing Machines
Baby lock quest
The top thread is looping right? This particular machine loves a well oiled hook system, and it needs to be vacuumed out regularly. Compressed air is not good on this machine, actually it is not good on any machine if the covers are on. So check for thread trapped inside the hook system by flooding with oil and oscillating the machine back and forth for a few minutes.
Two other possibles: something is snagging the top thread like thread trapped inside the hook system or a little burr on the stitch plate. Moving faster means the fabric tractors harder, so any burrs will be mre noticeable.
Dec 03, 2013 | Baby Lock Imagine
I have a Bernina Activa 130. I tried to sew over some leather, started fine, then the needle got stuck and I stopped right away. Now, the bottom threads keeps bunching. I have re-threaded the machine, new...
You need a fatter needle. The skinny needle will not open the leather enough for a smooth flow of thread and that's why the bobbin is bunching up when the top thread is sticking. Make it easier on your machine by using an appropriate size needle while sewing leather.
Nov 04, 2013 | Bernina Activa 130
Hi! the top thread keeps falling out of the needle. can you help me?
Are you holding both threads at the back of the pressure foot when you start each seam? This one thing will help to prevent lots of thread into rotary hook problems. You should hold the threads, start stitching for 3 stitches forward, 3 backwards, then at least five forward again before you release the threads, then continue to guide the fabric wit your hands as you seam. Provided you hold the thread tail when you start stitching there should be no reason why the thread is pulling from the needle.
Also check your top thread is not getting caught/snagged on something enroute to the needle and that your top tension dial is set to 5? Perhaps if you have tension turned right up, this would prevent top thread from feeding smoothly to the needle.
May 23, 2011 | Singer 2250 Tradition
Top thread gets stuck around bottom bobbin and jams machine
have you tried oiling it after you clean out all the dust and thread ends, you can take the feed dog plate off and clean under there as well. hope it helps
Jul 22, 2017 | Euro-Pro Shark 80 - 7133
Stitches a bit then fabric doesnt move, appears to get caught in feed dog
Here are a few things to try.
* Reselect the proper stitch pattern and length.
* Set presser foor pressure adjustment lever to "normal".
* Raise feed dogs.
* Place both threads back under presser foot before beginning to stitch.
I Hope this helps you.
Sep 18, 2009 | Kenmore Sewing Machines
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer 8280 is not giving me a useable stitch due to tension is not properly feeding resulting , no interlocking
Make sure that the thread is not getting caught on the handle. I was having the same problem and tried everything only to find that my thread was caught.
Oct 28, 2008 | Singer 8280 Mechanical Sewing Machine
First 5 stitches my thread tabgles
I believe it is recommended to hold each thread until the stitching gets started, see your manual. I make sure the slack is removed from each thread just before putting the presser foot down, then just put a finger on the threads, clamping them between your finger and the sewing bed, until a few stitches are done. This can be done through the material being sewed.
Mar 01, 2008 | PfaFF Creative 7570
Sew D'Lite Lightweight Portable Mechanical Sewing Machine Logo
56 people viewed this question
Top Sew D'Lite Sewing Machines Experts
Level 1 Expert
Renee Knafel-Bullock
Are you a Sew D'Lite Sewing Machine Expert? Answer questions, earn points and help others
