Question about GPS
Power station ps1100
Unit will not charge up
How to charge
• IMPORTANT: This unit is delivered partially charged.
Plug into an extension cord FOR 40
hours before using.
You cannot overcharge the unit using the AC charging method.
• To recharge this unit, use only the supplied AC charging adapter.
• All ON/OFF switches should be in the OFF position when the unit is charging or not in use. Make sure all switches are in the OFF position before charging. Here is the instruction book:
http://ecx.images-amazon.com/images/I/81US%2Bom6xKS.pdf
here is the booklet.
Jul 21, 2014 | Stanley Tools 500W Portable Power Station"
Will a kensington universal docking station work with my sony vaio pcg-7d2l
Yes it should if you are running Windows XP, Vista, 7 or 8. You just connect to the unit using a spare USB port on your laptop and a plug-plug USB cable. It has it's own power so you'll need a mains socket. This means you can unplug your laptop and leave any devices charging on the docking station USBs. Your laptop should auto-instal the station. I believe there is a table/support available which combines with this unit. There a varying prices for this unit so look around.
Good Luck
Feb 27, 2014 | Kensington SD400V USB Docking Station with...
Mains adapter for auto-xs power station not working
It could be that the internal battery is too discharged for the AC charger (as supplied with the Power Station) to work.
You could try charging the Power Station using a Vehicle (Car/Motorbike) 12 Volt battery charger, connecting the Crocodile clips on each unit.
I''ve just done that, although once 'I'd got the Power Station battery's voltage above 2 Volts, I used a 'special' charger (Optimate 5) that automatically applies several modes including 'Desulfation' for recovery.
Oct 05, 2012 | Cameras
VTech 2651 base (2.4GHz) +3 phones - base not charging, has power
email me, i may have a bbase for you, put vetech phone base in the subject line. thanks
tim
my email tpmtpm@aol.com
Nov 04, 2009 | Vtech Lands Phones
I just found my HP Pocket PC 2003 Pro, it has been MIA since we moved in 05. Unfortunatly I only found the unit itself and the docking station. It was my first and when it was lost I just went back to...
If it has been hiding for 4 years the battery is probably broken. Your should still be able to find a new battery on ebay for it. Or maybe from HP but it will cost a bit more.
Sep 17, 2009 | Microsoft Windows Mobile 2003 for Pocket...
I unplugged the docking station and now does not work
I actually had the same issue with mine.. it was 6 years old and just stopped finding the docking station. Also wouldnt take a charge. So I just eliminated the docking station. The stations power cord will charge the unit. Hope this helps.
Sep 12, 2009 | Roomba Robotic Floor Bagless Vacuum
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Dell D600
If the docking station is not charging the laptop while docked, it may simply need to be plugged in using the power cord to recharge the battery.
Jul 21, 2008 | Dell Latitude D600 Notebook
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Station Preset Memory Lost When Power Off
Have same unit, exactly the same problem: station presets lose setting when power is off. I've opened the unit; there is no apparent battery of any kind.
As long as the unit is powered up, the station pre-sets seem to hold. There IS a capacitor across the power switch. Some A/C will therefore be transmitted into the unit when plugged in, even with the switch off. If the capacitor is open, no charge will enter the unit when the power switch is open. I will probably replace this capacitor and see if that fixes things, but it may take several days to do so. Has anyone else tried this?
Feb 02, 2007 | Kenwood KR-A5080 Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
