Question about Nikon COOLPIX L3 Digital Camera
Camera doesn't do anything!
So, I've got a string of events that lead to this problem. At first I got a Lens Error message on my screen, and so I jiggled it around, fixing the problem... I thought. I continued to use it as normal, each time I tried to turn it off, needing to jiggle the lens around to get it back in. Finally, it stopped working altogether. My lens wouldn't go back in and now every time I turn the camera on, I get a blank white face on the screen and absolutely no reaction from any of the buttons. I can't even turn it off properly, instead I need to take the batteries out to do so. Help! I loved my camera soo much!
    Genius:
  • 2,985 Answers
But it is time to bury it and get a new one. I feel the repair cost will be very high. Check out Nikon Support first though
Posted on Aug 30, 2007
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
I have a Caso Exilim EX-Z90. Many months ago I tried to turn it on, then lens came out, but started making a sound like it was struggling and a message like "lens error" came up. I've tried...
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Casio service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Jul 01, 2011 | Casio Exilim Ex-z90 Ex-z280
I was taking photos when suddenly my Canon PowerShot SD 1300 IS IXUS 105 read "Lens error. Will shut down automatically. Restart camera." Then the screen went blank. The lens will not retract....
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
May 25, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Nikon COOLPIX L3 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
