Question about Keurig 5048 My K-Cup Reuseable Coffee Filter
Why does my Keurig k-cup leak from the bottom.
My k-cup maker leaks every time I use it .It is leaking from the bottom in the back of my machine.The more I use it the more water I have on my counter And not in my cup. And I have noticed it only does it If there is A K-cup in use.I can take the k-cup out and get hot water the frist cup will leak but the next cup of water it will not and every cup of water after it wont.Butputanother K-cup in and it leaks away.
  • 1,511 Answers
Needs cleaning or seals get damaged.
Posted on Jan 31, 2014
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Posted on Mar 02, 2009
  • 460 Answers
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
Posted on Nov 12, 2009
SOURCE: leaking water when using my k cup
Long story short, it will leak from under the screw cap (rarely) and from the rubber ring around the puncture pin. The grounds clog the metal filter and creates pressure that escapes from under that rubber ring. I cut a thin styrofoam plate to fit under the screw cap. It's really snug for the first few times, then it will loosen up. Second is to tighten the seal between the top of the 'my cup' and that rubber seal. I used 2 styrofoam rings that sit between the 'my cup' and the hard plastic it sits on when you fit it in the hole. It bring the cup like 1/8 inch higher to the pin and increases that seal. I made many cups after that and it has never leaked. I'm looking for a good rubber ring to fit around the 'my cup' to replace the rings for the seat.
Posted on May 06, 2010
espressonist
  • 1711 Answers
SOURCE: water leaks out the bottom
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler . All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Posted on Sep 27, 2010
SOURCE: The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
Posted on Dec 27, 2010
Keurig coffee maker model b70
Not to be coy, but the best way to repair this problem is to take your Keurig back to Bed Bath & Beyond and exchange it for a brand new one!
As for your problem, your description was not detailed, but I would guess that the leak you are referring to is not coming out of the reservoir at all, but is actually coming from the bottom of your machine. The reason for this is that there is a solenoid located in the back of the unit that is notorious for leaking over time. The only way to repair it is to completely disassemble the unit and replace it. This solenoid is also responsible for your Keurig to "short-cup" you, meaning your Keurig brews, but you only get a partial cup of coffee. If your unit has not done this yet, it will start shortly.
So back to what I said at the beginning, your best option is to simply return it to BBB for a new one. You do not need a receipt, nor have had purchased it there in the first place. If you are interested in this option (& I highly recommend it), please send me an email at tom.morgan451@gmail.com. And I will send you al the information you need on how to return it for free. If you decide to send me an email to learn about this, please let me know in the email that you were from Fixya.com. If you want to know more about why the Keurig leaks and how to repair it, please search You Tube for my video series call Keurig Operation and Repair. It's long, tedious and extremely boring, but skip around and then send me an email. You will be happy you did. Good luck and IO hope this helps.
Jul 27, 2014 | Keurig Platinum B70 Coffee Maker
Keurig b60 is pumping the water back into the tank instead of the cup as well it is leaking out the bottom of the machine, i have tried cleaning the needles however, not sure what's causing it to do t
Check the water output in the brew head itself. Open the head like you were going to out in a k-cup, and run a small object like a paper clip UP the water output to make sure it's clean. Then remove the K-cup holder and clean the water output line at the bottom the same way.
Mar 25, 2014 | Keurig Special Edition B60 Coffee Maker
My Keurig leaks from the bottom, it's a pain.
You may have water in the holder that supports the CUP. It needs to flushed as it has a limited area for maintain the overflow.
Mar 12, 2013 | Keurig Platinum B70 Coffee Maker
My keurig is leaking from bottom
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Oct 02, 2011 | Keurig B60 Coffee Maker
I have a B60 and it is leaking from the bottom of the coffee maker, not the tank. Is there a seal that has gone bad and can be replaced?
One of the hoses is leaking inside... a very common problem...it can be fixed, but getting the machine apart is difficult...
here is a tip that has a picture of the machine with the covers off...
Keurig One Cup Coffee Brewer will not turn on
heatman101
Aug 30, 2011 | Keurig B60 Coffee Maker
It leaks
Here is a tip that I wrote about Keurig coffee brewers and the Keurig leaking problems
Keurig One Cup Coffee Brewer leaking
heatman101
Aug 28, 2011 | Keurig B70 Coffee Maker
We use distiller water..6 months old.. Lekig constantly...any suggestions
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Aug 01, 2011 | Keurig Platinum B70 Coffee Maker
Permanent Keurig filter leaks
Are you using the my k-cup with the Keurig pre-filled K-cups? If so it won't work. There must be a needle on the top and bottom of the K-cup for this machine to work. The My personal K-cup does not have a needle in the bottom. It's only to be used for filling with your own coffee.
Sep 17, 2009 | Keurig B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
411 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
