My television does have a display problem - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
What is the problem you do notice with the display? Provide more details please. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Posted on Apr 26, 2013
Television won't pick up signal from tablet using hd mini micro cord
Most of the time this is a case of the output resolution from your tablet does not match the resolution of your television.
Go to the Control Panel on your tablet and make sure the secondary video output is set to a resolution that the television can
display. Try 1280 X 720 and see if it displays. If this resolution does not work do a Google search on television resolution
settings and try the other standards.
Televisions for the most part compared to monitors can only display specific resolutions.
Sep 25, 2013 | Acer Aspire One PC Notebook
Television screen displays production: runin when dvd player is operating
television screen displays production: runin when dvd player is operating
May 07, 2010 | Westinghouse SK-26H590D Television
No laptop display on television
adjust the tv resolution to near to that of monitor's.use the compatible hdmi cable and also go for display options.
Dec 04, 2009 | LG 42LC2D 42 in. LCD HDTV
I have an iMac G5 2Ghz that when it start up you can only see video for a few seconds. I connected an external monitor and my iMac works fine but with its on LCD there is no video. I check the logic board...
Sir,
The iMac G5 and iMac G5 (Ambient Light Sensor) computers have a video out port located on the back of the computer, which will mirror video. Video mirroring means you can see the same image that is on the iMac G5's flat-panel display on an external monitor, television, or projector.
Using the video out port, you can mirror video with a compatible VGA display using the Apple VGA Display Adapter.
You can also use the video mirroring feature with a television or projector that has S-video or composite video connectors when you use the Apple Video Adapter.
Both the Apple VGA Display Adapter (M8639G/A) and the Apple Video Adapter (M9109G/A) are available separately, and are needed if you want to use your iMac with a VGA monitor cable, S-video cable, or composite video cable.
The video mirroring feature is "plug and play". Simply connect a VGA display, television, or projector to the appropriate adapter (see above), then connect the adapter to the video out port located on the back of the computer.
When you connect the adapter to the computer, the screen may refresh momentarily as the computer prepares itself for the new video output. The computer tries to match the resolution of the built-in and external display. If there is no match, the computer changes both screen resolutions and may black out areas on the built-in display in order to match the capabilities of the external display.
Important: To ensure that your iMac G5 automatically detects the external display or projector, be sure you plug the adapter into the external display or projector before you plug it into the iMac G5.
You can switch resolutions and frequencies for both the iMac G5 flat-panel display and the external display, television, or projector using Displays preferences.
Want to watch a DVD movie disc on a television that's connected to your iMac G5? Select a 720 x 480 NTSC (in the United States) or 720 x 576 PAL (in Europe and other regions) resolution in Displays preferences.
Tip: Because of the display limitations of most televisions, the images displayed on a television screen are usually not as high quality as those on the built-in display or an external monitor.
Thanks
Good Luck
Aug 21, 2009 | Apple iMac G5 Desktop
Display box keeps popping on and off on screen
Your display box continues to pop up because of the way your optimum box is connected to the back of your television. If you are connected with a coaxial cable from the box to the back of the tv, you will get that display box. The reason you are getting it because of the weak signal coming from your coaxial cable(which is the worst cable to use when connecting ANYTHING to ANY tv, especially a lcd tv). That cable is sending a fluctuating signal and your television is adjusting to that(hence the reason the display box comes up). Use composite cables(typical red, white, and yellow cables) to connect your box to your television and I guarantee your problem will be solved. Make sure you unplug that coaxial connection from your box to the television.
Dec 08, 2008 | Sharp Aquos LC-32D40U Television
Connecting Television to Computer
does the tv have an hdmi, fpc or vga connector? these are the prefered inputs from a PC.
Dec 06, 2008 | Televison & Video
Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do i set up the lg 32lc7d to display my laptop computer desktop
i want my laptop computer desktop to display on the flat panel television
Dec 28, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
