Question about Xerox ColorQube 8700X - multifunction fax / copier / printer / scanner color
Printer Status Not Available at this time - Xerox ColorQube 8700X - multifunction fax / copier / printer / scanner color
Network printer sending message on desktop " printer status is not available at this time"
Check the network setups, is it set to DHCP has it been issued with a valid I.p. Address. E.g 192.168.0.123 etc?
try printing out the network setups from the printer, that might shed some light on the problem once you have all the network information at your fingertips it's much easier to make a valued decision.
Good luck.
Oct 24, 2013 | Xerox Phaser 8560MFP Laser Printer
CLP-325 "The current printer port is not supported for the printer status"
Dear
Try to replace the usb cable. Also from pc program do the maintenance program run.
If still problem found check the printer with other pc or the pc usb port for other device if it works then replace the main PBA of the printer.
Thanks.
Apr 28, 2012 | Samsung CLP325 Laser Printer
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Receive message Printer status is not available at this time when trying to print
Getting "printer status is not available at this time" when trying to print
Apr 09, 2010 | Xerox Phaser 8560MFP Laser Printer
Status light on printer is constantly red & USB status is not ava
Unplug printer and wait a few and then plug back in and turn on. Should reset printer.
Mar 29, 2010 | Samsung CLP 300 Laser Printer
Won't print - Error message
You may have to re-install your printer drivers to solve this problem.
Sometime it happens.
Please don't forget to rate this answer if it helps.
Sep 08, 2009 | Office Equipment & Supplies
Can't print from shared printer
Did you connect the printer directly to the laptop to install the drivers? If so, you need to change the port to the network location to //hostcomputer/printer. You should also have the same user name and password set on both machines and have the user rights assigned to the printer sharing.
Jan 24, 2009 | Epson Stylus RX500 All-In-One InkJet...
Xerox ColorQube 8700X - multifunction  fax / copier / printer / scanner   color Logo
312 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
