Question about GE PSS26NSWSS Profile 25.5 Cu. Ft. Stainless Side-by-Side Refrigerator
All of the lights in the refrigerator side are out.
The refrigerator is working properly. How do I fix this? The LED lights will turn on but turn off after a few minutes
  • GE Master
  • 4,655 Answers
Can you provide the model number found somewhere around the fresh food section door? When you say LED lights it call to mind the GE Monogram but it does not have LED lighting. Here is a link to that Service Manual HERE I need your correct model number to look up the wiring diagram. From looking over other diagrams the problem could be a bad door switch, loose connection or a defective relay on the motherboard. I will be here to answer any questions, Thanks Sea Breeze All of the lights in the refrigerator side are out - 792bf8b3-72e7-4ea7-b313-81ae6db327a8.jpg
Posted on Apr 26, 2013
Testimonial: "I found out that it was a simple stuck switch. Found it from looking at pour picture even though I have a GE profile. Thanks"
4 Suggested Answers
hapndnvegas
  • 35 Answers
SOURCE: GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Posted on Mar 27, 2008
57 varieties
  • 1653 Answers
SOURCE: The refrigerator side is not running or cooling.
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Posted on Aug 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My lights went out today for a few minutes, now my refrigerator is not working properly. The lights are on but the ice maker or water is not working and its not getting cold. What could be the problem
It sounds like your motherboard=> WR55X10942 took a hit from a surge. Unplug for a while and replug and see if compressor will come on. If not then unplug and pull away from wall, remove panel covering motherboard and carefull examine both side of motherboard for burn marks and melted solder. If you would like me to give full details of how and what to replace please ask. You model is known for being tricky to repair and asking for assistance would be a good idea if you plan to do this yourself, Thanks Sea Breeze
GE Refrigerator Technical Service Manual
Posted on Apr 24, 2012
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
Bought LED 8w(50W) bulb for range hood, bulbs work fine when turned on to regular mode but don't work on the second setting that supposed to make them a little dimmer. Do I need dimmable bulb or is this...
not a bulb problem, the computer board is what makes the light dim. for the price of replacing the main board i would just let it work the way it is. if the light fails completely, then think about a new board, but its not really a thing that is needed.
Dec 30, 2013 | Maytag MZD2766GES Side by Side...
Despenser light no longer works.
if you mean light for water and ice dispenser they upgraded to a new led ring mine went out to you can get part from bosch parts website
Dec 08, 2013 | Bosch B22CS80SNS (220 cu ft) Side by Side...
LED Accent Lights in Sub-Zero 650G Glass Front
I have the same problem with the LED accent lights! Did you ever find a solution?!
Thanks!
Mar 31, 2013 | Sub-Zero 650 / O Bottom Freezer...
I have Accer Mini tower with dou core 3.0 processor i remove the cpu fun with the heat sink to add oil to the fun and a return back properly i didn't touch any thing but after i turned on it , the fans...
Hi
Before your computer running fine, you just remove the fan and heat sink, and fix properly.
1) Check your VGA cable both of side fix properly
2) Check your Monitor power button is switch on.
3) Remove your RAM and fix again.
May you fix your problem
Jun 01, 2011 | Acer Veriton M460 Micro Tower Core 2 DUO...
Kenmore coldspot ice maker quit
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore side by side refrigerator model 106.5702 will not make ice.
your ref board seems to be working fine
Did you test the water valve???
if yes and water valve works, than replace the Ice Maker
May 11, 2008 | Kenmore 53703 / 53706 Stainless Steel Side...
Mar 02, 2007 | GE GSH25JFR Side by Side Refrigerator
GE PSS26NSWSS Profile 25.5 Cu. Ft. Stainless Side-by-Side Refrigerator Logo
216 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
