Question about Compaq Computers & Internet
Active partition not found, have run ide ids test all ok, as it is a win Xp pro I have put disk in the cd rom and no joy...anyone any ides on how I can put win 7 on this even though this is not what was previously installed
  • 1 more comment
  • Brian Sullivan
    Brian Sullivan Apr 25, 2013
    So you decided not to jump from Windows XP to Windows VISTA. but now you're ready to LEAP forward into Windows 7. First, you will want to BACKUP ALL of your programs. Since you did not upgrade to VISTA, you will LOOSE all of your programs when you upgrade to Windows 7, so be sure to backup all of your programs and files. If you wish, you can use an external hard drive and a program called WINDOWS EASY TRANSFER to make this task easier. See the link below for this FREE program. http://www.microsoft.com/downloads/detai... Now, for the fun part! Insert the Windows 7 disc into the computer and start or restart the computer. Follow the onscreen instructions to completely install Windows 7. You will now need to reinstall each of your programs. If you used Windows Easy Transfer, you can use the list of programs that it prints out to be certain that you reinstall all of your programs. If your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 2GB of RAM to install windows 7
  • ricardo cafolla Apr 26, 2013
    Many thx for the advice Brian ... ))
  • Brian Sullivan
    Brian Sullivan Apr 26, 2013
    no problems hope it all goes well
  • Compaq Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
http://www.nextag.com/dvd-lens-cleaner/shop-html
Posted on Apr 25, 2013
lars_olsson6
  • 3400 Answers
SOURCE: Cannot boot from cd rom
check out cd/dvd-writer.if any dust partikels clean with caned air.
Posted on Apr 22, 2013
fixxerss
  • 61 Answers
SOURCE: Acer T650 Ide and Sata Problem
blue screen means system error or hardware problem. maybe your sata drive is the problem. try to use another sata drive.
Posted on Feb 16, 2009
mnelsonix
  • 58 Answers
SOURCE: IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
Posted on Apr 07, 2009
myjosh007
  • 530 Answers
SOURCE: unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
Posted on Apr 09, 2009
  • 115 Answers
SOURCE: I bought a couple of used Dell Optiplex GX520s
yes it has problem handling large hdd but not with dvd drives. it supports up to 120 gb hdd. as it has a low powersupply.
Posted on Oct 26, 2009
Testimonial: "Thanks. I won't be able to test your answer unless I buy another HDD, but it confirms my own diagnosis of the problem."
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
Hi, I have a HP NX6310 notebook with Win Xp Pro installed. I need to reformat it after it was heavily virused, and reinstall Win Xp but without the recovery disks I am rather helpless. The recovery...
You can't see any HDD's when trying to install because your BIOS system was set the IDE controller to an AHCI, you can set this to native IDE and windows XP setup will read a HDD's..
If you need set the IDE controller to AHCI you need Intel AHCI controller driver for your system, you can see it during installation process to press F6, you must use floppy diskette and put the driver onto it.
Another way to install AHCI driver is Integrate the driver into Windows Installation directory..See here for more details..
Aug 10, 2011 | HP Compaq nx6310 Notebook
Emachine ET1331G-03w Documentation
To install an IDE CD rom, you will need to open your computer and you will see an IDE Slot, your computer usually has two of them either directly next to each other or under each other, there is usually one white one and one blue one. IDE Slots look like this:
The white IDE Slot is usually for the Hard Disks and the blue IDE Slot id usually for the CD Roms.
The white IDE Slot is the Primary Slot and the blue is the secondary.
You will need an IDE cable to plug in to your blue IDE Slot then you will need to plug the cable in to your CD Rom and make sure that your CD Rom is set to run/work as the master. If your computer only has one IDE Slot or you do not have an extra IDE Cable you can plug the CD Rom in to the Primary IDE Slot with the Hard Disk assuming you are only using one Hard Disk.
If you are going to use the Primary IDE Slot you will need to make sure that your CD Rom is set to run/work as a slave and it must not be set as the master. The way to change it is by moving the pins at the back of the CD Rom, they are found at the back next to the place where you plug the IDE Cable in to or next to the power input. You will be able to tell if your CD Rom is set as a slave or as a master by checking the image on the top part of the CD Rom, this image will tell you how to set your CD Rom as a master or as a slave.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | E-Machines eMachines Desktop PC
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Apr 07, 2009 | IBM NetVista PC Desktop
Hard drive does not hold windows xp
When you install windows and it's shows you 1 or 2 partitions, it's asking you if you want to DELETE partition, - say yes and delete all partitions you have, so when you done deleting all you'll have ~ 79GB of UNPARTITIONED spase. Only then, format as NTFS and install Windows.
Apr 05, 2009 | Fujitsu Computers & Internet
Missing hard drive on a Win 98 computer / datarecovery ?
The best you can do is buy a small cable (+/-€ 10) IDE-USB. This cable lets you connect your IDE drive on a pc using USB.
Jan 05, 2009 | IBM Deskstar 75GXP (DTLA-307020) 20.6 GB...
Boot problems!
Hi gcooper1873,
If your primary IDE has a copy of windows already on it, than that alone can cause the system to re-boot & go into a loop of re-starting. It is alway recommended to install windows fresh when a user replaces the motherboard with a new motherboard. The only execption to this rule is if your replacement board is an exact match of the motherboard. Plat it safe. If you have another IDE data cable replace your current data cable. See if the system restarts.
If you have data on the primary IDE & do not wish to loose the data from your old windows than you need to create a new partition within the IDE's free space. This should stop the system from restarting. You can leave both IDE drives connected for this. Load your Windows XP CD & boot to it.
If the system does not load the Win CD than manually restart the system & press the F8 key every two seconds as the system boots. You should get this screen:
High-light the CD-ROM with the windows CD in it & press enter.
Read the display from windows XP's screens. You want to create a partition within the free space of your primary IDE. Than you want to install windows onto that new partition. By doing this you will not loose any data from your old windows partition. (You'll be able to delete the old win partition later).
Install windows complete & install all of your motherboard drivers from the Gigabyte CD.
Turn on windows firewall for protection. Click on, Activate Windows & do so by phone. Its free.
Update window. (Suggestion, when updating windows look through the updates & find .Net framework 1.0) & install. Its prefered to install all .Net framework's in order. ( 1.0, 1.1, 1.1 hotfix, 2.0, 2.1 ECT). Windows will want to restart your system inbetween some of these. Do so. You will also notice you may have to click on your user ID to log into windows, this will go away after all .Net frameworks have been installed. Do not remove guest from within user accounts in control panel. Once windows updates are finished you can now copy the old partitions data folders to the new windows folders.
Suggested folder's to copy:
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you may have installed.
Now you need to get rid of the old partition with the old win XP on it.
Use windows disk management program.
Click the start button, click on run & type in " diskmgmt.msc " & press the enter key.
You'll need to change the old win partition to a different drive letter. Example: Your IDE drive had one drive letter assigned to it - C:\. Windows most likely kept the letter C:\ assigned to your old windows.
With disk management you can re-assign all your drive letters. Once your sure you have all your data copied over onto the new installation you can delete the old windows partition.
Which one of these motherboards is your's? Click the link below;
http://www.giga-byte.com/Search/Search_List.aspx?Keyword=GA-P31&SearchType=Spec
Good luck gcooper1873!
Any question? Post it here....
Mike
Oct 21, 2008 | Intel Motherboard
Computers & Internet Logo
119 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
