Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer will spin to dry but water comes back after short time
Our Kenmore stacking washerdryer has a problem we are trying to diagnose. The problem is at the end of the spin cycle the water is spun out of the clothes but usually within 5 minutes an inch of water comes back into the tub. We had appliance repairmen over to look at it and they replaced the pump and one of the valves. It still had the problem after this so we snaked the line with a hand snake 25 feet. The repairmen thought there might be a problem with the drain. This still didnt help so we had a plumber come and roto root the line. That didnt help either. Apparently there isnt a vent stack on the drain and the drain was originally sealed onto the drain pipe when the unit was installed in 1994. However we cannot see inside the wall to know for sure and strangely enough even without said vent stack the washer has drained properly up until 5 months ago. We dont want to do exploratory surgery without a good reason since the unit has worked well for almost 20 years.
  • Maytag Master
  • 2,694 Answers
How far down is the drain hose pushed in to the drain pipe?should only be like 3 to 4 inches,also the drain hose should be up higher than the water level in the tub.if you can pull out the drain hose try this,fill up the washer on small,after it fills,pull the hose out of the pipe and then stick the hose a few inches into the drain pipe and then turn the timer to the spin cycle and let it drain,after it stops,pull the drain hose out of the pipe,if no water enters back into washer you know that it has something to do with the way the drain hose is in the pipe or another problem.if you're saying that the drain hose is sealed to the drain pipe in the wall you will have to get in there and separate it,pull out the hose and check it,it sounds like this is where the problem is,you had the pump changed and i don't know why the guy would do this if the washer was draining so you know that's not the problem and if they changed the water valve on the washer you know water isn't leaking into the washer from the valve so i would check the drain hose.hope this helps
Posted on Apr 25, 2013
  • Sal De Apr 28, 2013
    did you check the drain hose?usually i see people who tape the top of the drain hose to the drain pipe or standpipe have problems with draining,i remove the tape,check how far the drain hose is pushed down into standpipe,adjust it to like 3 or 4 inches and put a plastic tie around both pipe and hose so it can't pop out and it works,some air has to be able to get into the pipe or it can cause siphon problems,not technicly sure how it works but when you free up the top it drains normally again.i know you say that it worked for like 20 years but something has changed in the pipe,either there were little air holes and they sealed up totally over the years,the hose could have swelled from over the years in the pipe or i went in on some jobs that were said to be snaked and went back and drain still was blocked,you can hear the water backing up the pipe,the plumber didn't want to move the stack out of the hole it's in,tight closet and snaked it from the bottom up,after he moved the stack and snaked it from the top of the pipe down it cleared so you either still have a blocked drain or something to do with how the drain hose is connected to the pipe,checking it would be the cheapest way to go,might be hard to get at it but if it isn't the pipe and is somehow the machine your gonna have to move it anyway to connect the new drain hose if you replace it.some of those old hoses can bend and kink too and it might not fit a newer washer,usually all the new washers have preformed hoses.hope this helps and hope you can figure this out so you don't have to replace your stack,i have a 25 year old maytag stack,i clean out the dryer every year,take it apart,use a shop vac,i vac up all the lint then blow all the lint out of the motor and the cabinet and luckily no problems,they don't make em like they used to.
SOURCE: Water won't completely drain from tub. Door seal is very moldy.
Had a simular problem. In my unit the water was not visible in the drum but you could hear it when you turned the drum by hand.  The answer as told to me by the Maytag repair man:  The machine is designed to hold the water after the cycle is complete.  As he was replacing the boot seal he suggested to just leave the door open so the seal will dry out and not mold.  This has been working for the past several years.  No mold has appeared on the new boot seal.
From another source I read that the water is left in the machine for balance.
Posted on Sep 27, 2009
SOURCE: Water in Outer Tub
My washer does this too and I called Maytag and was told it was normal. I don't like that answer, though.
Posted on Mar 08, 2007
  • 129 Answers
SOURCE: Maytag LSE7804ADE Top Load Stacked Washer / Dryer
you'll need to by a sink kit at any hardware store and a sump pump , be advise at the place you buy . good luck .let me know take care
Posted on Jun 15, 2007
  • 5 Answers
SOURCE: Clothes are not drying
don't know
Posted on Jan 13, 2009
kvhappliance
  • 218 Answers
SOURCE: Hello, On Neptune washer serial # 34098916EF,
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Posted on Mar 17, 2010
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Same problem, will not drain at all or spin
the front panel comes off and the pump run if an electric on 80.00-140.00 just remove 2 clamps and make sure you remove the water from the tub. but the good news is you may not have to buy a pump get you wet/dry vac handy and ready to remove the remaining water when you unhook the hose at pump from the tub once gone remove whatever is plugging then put hose back on and in spin cyc start it if you here the pump run you should be ok then try with a small amount of water put back in to spin if pumps out your good to go
Sep 03, 2009 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
