Question about Pioneer AVIC-D1 In-Dash Mobile Navigation CD Car Video Player
Pioneer in-dash navigation system AVIC-D1
The touch panel with the system referenced above is out of calibration. That is you actually have to touch the screen to the right of the button you want to activate. Therefore the buttons on the far right of any screen are not accessible. What can I do to recalibrate the touch panel without removing the unit and sending it back to Pioneer which is what they recommend I do?
  • 7 more comments
  • avicd1 Nov 26, 2007
    I have a similar problem and when I tried the solution given by bun6661, I can get to the calibration screen but I cannot select the "done" or "enter" on the joystick to accept and continue. Any suggestions please?
  • DLS28 Mar 21, 2008
    i have the same problem. when i get to the calibration screen and try to touch the plus sign up there it wont move. my email is [email protected]. if im doing something wrong please email me and let me know. i followed all the steps with tracing the outline of the screen and it still wont work.
  • stupordave Mar 22, 2008
    Loaded upgraded discs 2007 Teleatlas from a friends system but gave discs back a while ago and can't seem to get the older version of mine to be recognized. Any way to erase the memory to reload the old version?
  • jreed1 Jun 23, 2008
    I have exactly the same problem after 1 year. Pioneer wants $200 to fix it with a 90 day guarantee. Totally unsat!
  • gateway69 Jun 30, 2008
    I have the same problem with the screen calibration.
    I want to file a class sue action against Pioneer for seling a LEMON and not willing to admit and fix it. In cars they call it recall but for Pioneer everything is perfect and they "don't know" of any problem with the AVIC-D1, they also want $200 to fix their problem.
    If you want to be added to the class action please let me know.
    My email is: [email protected]
  • Anonymous Jul 15, 2008
    Had the same exact issue with my AVIC D-2. I was surprized the procedure to get the the correct menu are the same. The fix worked perfect. Since it's kind of a guess on how much to short the screen it took me a few tries to get it spot on.
    thank you so much.
    Ed
  • rickyrick123 Sep 07, 2008
    the keys are out of sync to the left
  • bcoryjames Sep 28, 2008
    I have the same problem. We actually sent ours back and paid the $200 to have it corrected, within 3-5 months it was back to the same problem.
    Its so bad now that I can't even use the nav at all, completely useless. I have a D1. I wanted to just buy a replacement touchscreen and install it myself, but I don't know what to get.
  • brandi11_22 Oct 23, 2008
    I have the same problem but I can't get to the point when the screen will say "press reset." I pressed the eject button and the reset button but it just goes to the generic green background screen. Is there something im missing?
  • 5 Answers
Hi, You set the screen so its all the way down and hold down the dvd eject then the reset button for a few seconds, then let off of the reset button, keep the eject button held down for another few seconds. Then the screen will say press reset. instead using the joystick, press up,up,down,down then push it in at the center. It will come up with options. the first one is touch screen test. using the joystick click on that one and do the calibration test. You will then have to trace the outline of the screen, while you are on the right side of it, trace it short to make up for the buttons on the right side. when you finish push the joystick in. it will say "settings ok" then go down to the 4th one, i think, and it will say something like test calibration settings and go to that one. It should say that the settings were saved. After that shut the key off and turn it back on and it should be good to go.
Posted on Aug 18, 2007
  • hmurr Dec 11, 2010
    It took me awhile to figure it out, but in the end i was able to recalibrate my screen. A little more basis information would of help the process even fast, but it work. thanks!
I went back and tried it after i saw what the enter button was and it worked, thanks. DLS28
Posted on Mar 23, 2008
The solution posted by Bun-6661 worked for me. The enter button was the p.adj on the bottom right. Thanks a lot for this forum. I saved more then $200!
Posted on Dec 15, 2007
    New Friend:
Where is the reset button located?!?!?
Posted on Apr 08, 2015
One additional tip. If your map comes up in New Jersey and your location is Cleveland, check your antennae connection. Signals for your location and route are received from your antennae. Especially check your connection if you have done any work behind the dash.
Posted on Jun 17, 2010
    New Friend:
I live in cleveland and my nav system avic d1 is stuck on new jersey how do i set it back to cleveland
Posted on Jan 12, 2010
    New Friend:
I have the same problem on my avic d-1, all of the buttons are so off the navigation feature is useless. It makes me want to punch through the screen. It does not help that i was using a garmin navigation seperatly in my car, and a week ago i was robbed they stole the garmin and a whole bunch of other stuff. So now i really want to re calibrate my screen to save buying another navigation. Oh well i am going to try bun b6661's solution and let you guys know if I am succesful
Posted on Dec 01, 2009
This one worked perfect on my AVIC-D1!!! The menu names were a little off, but fiddling around made it perfect, all for less than the $200.
Who is Pioneer to think that the user is not capable of doing this simple of a test on our own?????
Posted on Dec 14, 2007
I tried the above solution, but all i got was the following error message:
Navigation Initialization is currently
in process, or there may be an
improper connection of the Parking
Brake lead.
How do i recalibrate without getting the parking brake warning.
Posted on Jul 16, 2008
SOURCE:
Someone vandalized my pioneer nav system model avic-d1 shattering the screen. i need some advice onhow or where toreplace the screen
The best place I know of to get that unit repaired would be to send it to Pioneer
Service,Long Beach California. You could also try a company in San Diego, Ca. Called La Jolla Audio, But I Would send it to Pioneer if it was my deck.
Aug 20, 2010 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
My Pioneer AVIC-D1 Won't play Dvd's
avic-d1 is a cd player it is not a dvd player
Mar 07, 2010 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Touch screen doesn't work in some spots on my Pioneer AVIC-D1 GPS system.
THIS IS A COMMON PROBLEM WITH THIS UNIT. A PIECE NEEDS TO BE REPLACED INSIDE IT. CAN BE FIXED FOR $175. INQUIRE AT OUR SHOP
WWW.AUDIODEZIGN.COM
Jan 18, 2010 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Changing time on navigation
Time
Adjusts the systems clock. The time difference
(+, –) between the time originally set in your
Navigation System is set here.
You can also select summer time On/Off.
➲ Time settings ➞ Page 108
Summer Time
Choose whether or not to take summer time into
account.
On :
Summer time is taken into account.
Off* :
Summer time is not taken into account.
❒ When the period of summer time comes, or
when the summer time ends, your Navigation
System does not automatically change the
summer time setting.
➲ Change the summer time setting ➞ Page 108
Modify Current Location
Touch the screen to adjust the current position
and direction of the vehicle displayed on the
map.
Hardware Info
Touch “Hardware Info” in the Setting Menu to
display.
Connection Status
Connection Status ➞ Page 61
3D Calibration
3D Calibration ➞ Page 60
Service Info Screen
Displays the disc production number and version
information.
Mar 14, 2009 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Calibrating Pioneer AVIC-D1
You need to connect the hand brake sensor wire , Should be a light green wire , if you connect this wire to the car chassis you should be good to go , check the wiring diagram in the manual or hopefully it's still on your head unit.
Nov 25, 2017 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Avic d1 touch screen issue
The touch screen calibration is of, the screen has to be changed.Its 200$ from pioneer or you can look on ebay theres a place in ct. that will do it for 125
Sep 28, 2007 | Pioneer AVIC-D1 Car Video Player
Car Audio & Video Logo
3,123 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
