Question about Epson Office Equipment & Supplies
Epson 822+ Projector still dim after replacing bulb
4+ year old Projectors hung from ceiling in classrooms are so dim the image cannot be seen. changing bulb and doing the manufacturer's basic dust cleaning did not resolve the problem.
  • 25 Answers
I'm not familiar with your specific model, but are the units LCD or DLP? What I've seen in LCD projectors used in schools, museums, etc. that are left-on for several hours per-day, is that the UV filters in the optical blocks will fail. They usually change to an amber-brown color and block most of the light. It's the equivalent to putting sunglasses on. Do the units also exhibit a greenish-yellow tint instead of proper color?
Posted on May 01, 2013
  • 3422 Answers
SOURCE: Projection is so dim
Click HERE for the user manual.
I hope this helps.
Goodluck,
Please don't forghet to rate the solution
Posted on Mar 22, 2008
Marrie
  • 563 Answers
SOURCE: Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
Posted on May 13, 2008
  • 14 Answers
SOURCE: proector image is dim
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Posted on Sep 14, 2008
SOURCE: White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Posted on Apr 30, 2009
Need to adjust the brightness. The projection is too dim to see clearly in a classroom.
Appears bulb is burning out ?
If this is a replacement bulb, is it a proper replacement ?
Not all bulbs are dim-able.
May 12, 2014 | NEC NP100 Projector
Projected image too small
Did you replace the lamp with the EXACT type that was in the projector prior to changing it? Sounds like there is difference in lamps.
Feb 26, 2014 | Epson ELPLP42 PowerLite 280 Lamp
My projector has started projecting with a very dim image - very difficult to see even with room lights dimmed. It has been working weel with a great image until now - approx 1.5 years old used an average...
I've got the same problem. Just replaced the bulb but the image is no brighter. Our unit is two years old and operates about 6 hours a day. It is dimmer and more out of focus when run from a Windows computer.
Feb 04, 2011 | Epson PowerLite 410W LCD Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Projector works but image is very dim
Hello.
Here are 2 links for your Epson Powerlite 7300 projector:
User manual:
http://files.support.epson.com/pdf/pl53__/pl53__u1.pdf
User Replaceable parts list:
http://files.support.epson.com/pdf/pl53__/pl53__rp.pdf
And ... yes .. the replacement bulb for most projectors are very expensive.
Hope this helps.
Feb 23, 2010 | Epson PowerLite 7300 Multimedia Projector
One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
Dec 09, 2009 | Epson POWERLITE 400W Projector
I have an Epson projector on the ceiling of my classroom and have no sound coming from it? another teacher reset the projector and since have not had sound
go into the menu and select the speakers. if you have external speakers connected, select external. if not, selct the internal.
Sep 02, 2009 | Epson EMP-74L Multimedia Projector
DELL 1200MP projector problem
I don't know that particular model, but usually these are hung u pside down and the projector can flip the image. That should take care of it. Also, depending upon the angle to the screen, you may need to adjust the "keystone" as well. That will allow the final picture to be square as if the projector was at the correct angle.
Dan
Apr 17, 2008 | Dell 1200MP DLP Projector
The picture become upside down
You need to change it to front/ceiling in the menu function of the projector.
Oct 03, 2007 | Epson PowerLite 62c Multimedia Projector
365 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
