SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
Rinse not working, no water comes out. just cleaned filter as cold water was trickling in during wash cycle, so now water coming into wash cycle fine, but now rinse isn't working. if click to spin, works fine, back to wash works fine, but hangs up at rinse - no water comes out
  • Washing Mach... Master
  • 2,122 Answers
When the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Posted on Apr 25, 2013
freetek
  • 5568 Answers
SOURCE: just a trickle of water during rinse cycle
You write that the water flows fine during the wash cycle; if you mean while the machine is washing, then it is the pump  making the water flow. You need to watch the water flow while filling for any cycle since it could be slow filling and not running.
Since the same valve(s) control the water intake during washing and rinsing, what you describe doesn't make sense. I suggest your remove both ends of both hoses and inspect them and the mating connectors on the machine for clogged screens.
If these are clear of any sediment, then the flow control valve is failing. This is located on the rear of the machine and the screw connections for your hoses are part of the valve body. This assembly is pretty easy to remove and replace, is a common and not very expensive failure.
If you are in the US, check to see if you have a Johnstone Supply in your area. They sell mostly wholesale to tradesmen but have never turned a private sale away and are far less expensive than dealers with pricing ranging from 30-50% of dealer price.
Posted on Oct 12, 2008
BNewberry
  • 93 Answers
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Posted on Jan 12, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
buffalonyman
  • 1865 Answers
SOURCE: cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Posted on Apr 25, 2009
  • 6 Answers
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Posted on May 08, 2009
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Will not go through rinse cycle. Just hums.
Try putting unit on cold water wash///just to see if cold water is coming in to machine.... You see the rinse cycle uses only cold water the hum you here is most likely cold water valve..to fix turn water of remove water inlet line (cold) clean water inlet screens( there is also screens inside the valves) hook back up turn water on check for leaks test .If this helped you please vote/// need more help please ask....
Feb 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Won't agitate
Hiya,
these noices are often caused by a water issue the rince cycle is a cold water intack so i would surgest turning of the cold water at the mains or shut off valve then disconnect your cold intack hose & check for any clogging it could be a build up of lime scale or lint & the simple removal & cleaning of this hose could fix your problem.. alternativly ensure the cold water supply is turned to the on position to allow the water trough to rince
Hope this helps
Apr 22, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
No water for rinse cycle
Take the fill hoses off the machine and clean out the filter inside, right where the hose attached to the machine. Also, check to make sure there are no filter washers in either end of the supply hoses. Sounds like you only have to check the cold water side in this case.
Nov 08, 2008 | Whirlpool Washing Machines
Rinse cycle
most new washers have a cold water only rinse be sure cold water hose is connected to cold side of valve and turned full on ..be sure to ck screen inside cold connection on valve for sand or some other restriction
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Stoping before draining
make sure you have cold water unit rinse in cold water only,,even if it says warm...check the inlet vavle it should be humming in rines the cold sideof valve,,if not humming replace,,if working ok replace lid switch
Jul 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting FIXYA.com
May 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Whirlpool LSR6333LQ0
ch, first thing you want to do is check the hose going to the hot side of the inlet valve. There is a screen on the inlet valve that could be plugged with gunk,grit or sand. Remove the hose and clean it out. The humming you hear is the valve energizing. Something is preventing the water to come through. The rinse is usually cold water so that is why Im suspecting the hot side is plugged. Check this first and if that doesn't fix it, it may be the valve itself...Catriver..post back.
Apr 26, 2007 | Whirlpool LSR6334LQ Top Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
