Question about Exercise & Fitness
TG xt pro 600 treadmill-error 2 and error 5
Hi,we have two treadmills TG xt pro 600. When we turn on,one of them shows "error2",the second one shows "error5". Anyone can help us.
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
ercupa190
  • 12223 Answers
SOURCE: Treadmill Vistafit TS5506E shows Error2
adjust the speed sensor, clean it, and tight the wires connector very well.see the diagram
2) measure the input voltage motor, if there are the motor need repair
3) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block d.
God bless you
Posted on Jul 22, 2012
Whether someone can show me a picture of the treadmilltreadmill technogym run xt 600 with open motor cover? Thanks
If you wish to get some details about treadmill repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 17, 2016 | Exercise & Fitness
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
BH Pioneer pro Motor won,t run more than few seconds Error 1 showing cuts out reset does not do anything
cad8d0f1-568e-4bca-aef5-30bf8d5e41c0.gifsee the video attached and proceed according. lube the rollers bearing front+back too.
2) Run the software calibration for easy diagnostic and fix it.
3) See the diagram attached for s. sensor.
4) See my personal TIPS for help
God bless you
Oct 22, 2013 | Bh Fitness TS2 Folding Treadmill
Change language on technogym treadmil
go to the MENU and proceed with the instr. manual for to change the language.OR download the owner manual free.
go to www.fitness.manualsonline.com
God bless you
Dec 06, 2012 | True Technogym Excite Run 700 Treadmill
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
see the block d.
God bless you
Jul 21, 2012 | Exercise & Fitness
I have star trac pro treadmill,when i shifted from another place it show the error
1) Run the software calibration for diagnose, troubleshooting.
2) However adjust the reed switch, clean, and tight any wires connector see the diagram
3) adjust the speed sensor, clean, and tigh the wires connector see the diagram attached.
Jul 06, 2012 | Startrac Fitness Products Star Trac Pro S...
I got dkcity treadmill model number- DK5320HRP ' When we press start button the motor does not turn and after few second an error E1 showing on the display. plaese if anyone can solve this proble
I got dkcity treadmill model number- DK5320HRP ' When we press start button the motor does not turn and after few second an error E7 showing on the display. plaese if anyone can solve this proble
Jan 02, 2012 | Exercise & Fitness
Exercise & Fitness Logo
451 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
