Question about Kenmore 23822 Top Load Washer
Washingmachine kenmore 110 sometimes it will wash other times it just buzz
  • horney Nov 27, 2007
    i need to replace the top loader switch
  • 641 Answers
It sound like a motor or a belt issue. Open the machine and look for belt's condition and does the motor spins. Good luck!
Posted on Aug 17, 2007
6ya staff
SOURCE:
Kenmore 1107672267576722 not filling nor washing
sounds like no water coming into washer?if you go to fill it do you hear a buzzing or humming sound?if so bad water valve located in the back where the hoses connect to the washer or the water shut off is off in the house and no water going to the washer.the model number you sent is to long,after the 110 it should have 8 more numbers and that's it.
Jul 12, 2014 | Kenmore 22422 Top Load Washer
My Kenmore 80 series model 110 hot water continues to trickle in even after cycle is complete.
The fill valve is not shutting off completely. Sometimes it is necessary to turn off the water supply between wash sessions to prevent this but then you have to remember to turn the water back on the next time you plan to wash
Feb 10, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
[email protected]
Aug 21, 2009 | Kenmore Washing Machines
Buzzing sound
does it ever give an error code? a common problem on whirlpool made machines is the dispenser arm getting caught when changing positions. This part is in rear of detergent dispenser housing and uses a motor and a arm to select detergent/ softner/ bleach/ and fill. you can remove top (screws on back) to watch this.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Mid-cycle my washing machine stopped working.
Could be one of three issues, timer, capacitor, or the most like canidate the motor assm. Usually 90% of the time, its that motor. Those motors are pretty expensive (part number 389248) and you need to replace motor coupler (part number 285753A) when you change it.
Apr 20, 2009 | Kenmore 22942 Top Load Washer
Kenmore f l washingmachine 110.46472501 leak from dispenser
This is joyce
is dispenser in properly, remove and put back in. sometimes the peice that is seperating the solid from liquid is in the way and causes water to come out top.
also water pressure has a lot to do with this. has this changed. have you removed filter?
thanks
joyce
Feb 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Kenmore 23822 Top Load Washer Logo
71 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
