Question about HP Pavilion dv9000z Notebook
Gr dv900 i have verticle lines on my lcd....what is reason behind?i try lot to update graphics driver bt fail....what should i do
  • HP Master
  • 5,660 Answers
It\'s a hardware problem, Khizar, not a software problem.....
Problem is;
A) Graphics chipset
B) Video Cable
C) screen Inverter
(-> IF USED. Do NOT know if your Backlight source is LED, or CCFL. Cold Cathode Fluorescent Lamp. BOTH, are an option,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg )
D) LCD screen
Method is to diagnose, and see what the problem is
1) Graphics chipset:
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port; on the laptop.
(Left side towards the Rear)
This is a general example of a VGA connector (port), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down for VGA Cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
You have at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop, AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F4 key.
Good display on External VGA monitor, means the graphics chipset is OK.
Means the problem is the Video Cable, or screen Inverter (IF used), or LCD screen.
However there is an inherent problem, with the Pavilion dv9000 series of Notebook PC\'s.
The cooling for the graphics chipset is inadequate.
The surface area of the small metal plate, that is part of the Cooling Tube; is too small.
Here is a look at the cooling system. Cooling Tube and finned Heatsink, and Fan Assembly,
http://www.ebay.com/itm/HP-Pavilion-DV9000-CPU-Heatsink-Fan-438606-001-Genuine-Laptop-Tested-/160991132389?pt=US_CPU_Fans_Heatsinks&hash=item257bd1bae5
Set your mouse cursor in the middle of the photo. Do Not click at this time. Setting your mouse cursor in the middle of the photo, engages the Zoom In feature.
At the Top in that rectangular shaped aluminum shroud, is the Fan. Small black multi-bladed fan. The entire rectangular shape, is known as the Fan Assembly.
Coming away from the rectangular Fan Assembly, look at the small rectangular shaped copper plate.
That little bitty plate sits on the graphics chipset. It is TOO SMALL in surface area.
Coming down further you will see another small rectangular plate area. Has 4 \'arms\' in an X-shaped pattern, surrounding it.
This small plate area sits on the Processor (CPU)
Post back in a Comment, as to;
A) Does it state LED backlight on your laptop? Usually on the Palm Rest Cover, if so.
If not, then it uses CCFL backlighting.
[Light Emitting Diode
Cold Cathode Fluorescent Lamp]
Also post if the display is okay on the external VGA monitor.
If so we will go to diagnosing the Video Cable.
Often this is the problem. Either the connection at the motherboard is loose, or the LCD screen is loose; or the Video Cable has been damaged. (Stretched/Broken wires)
Connections have to be PHYSICALLY checked. Have to see if you can plug them in tighter. If this brings no joy, then Video Cable is removed, and a continuity test is performed.
Video Cable MUST be ruled out, before going on.
If NOT, you MAY buy a screen Inverter (IF used), and an expensive LCD screen; only to find out the problem was a $9 Video Cable all along.
After you post the above information I asked for, we\'ll go on........
Regards,
joecoolvette
Posted on Apr 25, 2013
    New Friend:
    Problem Solver:
  • 18 Answers
Screen has 1 white verticle line runs through screen from top to bottom amost in center of screen how to adjust or is it permanent
1) check both ends of video cable AND power cable are firmly plugged in.
2) update the device driver (or reinstall the current one if it is the latest issued by the constructor).
3) does this line permanently stay on your monitor, or not (it fades away after some time in session) ? does it appear everytime you switch the monitor on, or not (comes only from time to time) ?
If both answer are NOT, then there's a problem either with the monitor, OR the graphic chip in your computer.
To determine which is failing, try plugging your monitor on an other device, or plug another monitor in your computer.
Aug 27, 2014 | HP 2009M Monitor
My HP compaqnx9600 laptop screen display verticle lines, how can i remove them
Here are some steps that you can try.
- Hook up an external monitor.
- If the line is visible on the external display, try to update your video card driver. But if updating the driver will not remove the vertical lines, you are certainly having problem with the video card of the laptop.
- If the line is not visible, then the problem is with the LCD of the unit. Either you have to replace or check the connections of the LCD inverter or LCD cable.
- However, if you don't have any external monitor, go to BIOS setup (by pressing F10, or whatever key is designed to access the BIOS on your laptop) and check if the line is visible, if yes, you're having an LCD/screen problem. Either you have to replace or check the connections of the LCD inverter or LCD cable.
Hope this helps.
May 30, 2011 | HP Compaq NX9600 17.0-inch WSXGA+...
My hp pavillion dv90000 has gray verticle lines and it makes the screen behind really hard to see. What can I do?
In most cases with these lcds...when you see verticle lines and white outs, the most likely cause for this is a screen failure. Your lcd panel is failing and will fail, they are not servicable. First though check the data cable on the left side of the panel, it is secured in the back of the panel and it has been known to come loose from the socket annd this will cause visual problems of many different levels, but that is about it other than changing the screen out. These screen are relatively easy to change out and can be bought on Ebay for as low as 50 bucks.
Jan 06, 2010 | HP Pavilion dv9000z Notebook
Video displays vertical lines then goes blank
There could be 3 possible reasons for a vertical lines
1. Driver for graphics card needs to be updated
2. Grpahics card faulty
3. LCD problem
try connecting an external monitor and see if the display is also vertical on the monitor, if yes the problem is graphics card, if no, the problem is the LCD. Hope this helps
Dec 11, 2009 | Acer Aspire 5100 Notebook
Verticle lines across my dell lap top
Put your screen saver to black..let the screen saver come on if lines are there you need a new lcd.....if lines are not there uninstalll all graphics drivers reboot your laptop and reinstall this will fix it if not your lcd screen is on its way out.....NEVER CLOSE YOUR LAPTOP AND STAND ON IT THAT IS JUST SILLY THINK ABOUT IT PEOPLE I MEAN COME ON HOW STUPID CAN YOU GET YES PUTTING PRESSURE ON THE LCD WILL REMOVE THE LINES FOR A WHILE BUT THEY WILL COME BACK.
Aug 22, 2009 | Compaq Presario M2000 Notebook
HD Pavillion Media CenterDv8225nr Notebood Pc. Verticle stripes
I would try a couple of things. First and cheapest way is to try and update your driver. If that does not work, then try to remove and reseat your memory card(s), and if all else fails you will need to buy a new graphics card approx 75 to 150 depending on how good you want to go.
Feb 04, 2009 | IBM ThinkPad T21 Notebook
Graphic card problem.
Your graphics card is bad. The reason you don't see it on your bios screen is because it is not displaying in the high resolution high color graphics. Once your card starts displaying high resolution high color, then you get the lines. You need to replace your graphics card.
Jul 06, 2008 | Intel Motherboard
Blue Line
there might be problem with the input cable of monitor .... please verify the cable ... try replacing it and then check... this might solve the problem.....
Nov 17, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Vertical Lines in Monitor
I am using an Acer and my screen has over 25 lines now. Same vertical lines. Can anyone tell me what I can do to correct it??
Rasheed
Oct 07, 2006 | HP Pavilion zd8000 Notebook
HP Pavilion dv9000z Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
