HOW DO I DISABLE KASPERSKY KEYBOARD - Computers & Internet
How do I disable kaspersky keyboard?
You can dissable virtual keyboard plug-in in your browser settings. In Chrome go to Settings-Tools-Extensions and uncheck the tick in Active after the plug-in. Or
In order to enable/disable the option, perform the following actions:
  1. open the main application window
  2. on the right upper corner of the main application window, click Settings
  3. on theupper part of the Settings window, select Protection Center
  4. on the left part of the Settings window, select General Settings
  5. in the right part of the window in the Virtual Keyboard section, perform the following:
    • if you want to enable quick access to Virtual Keyboard by pressing the keycombination, check the box Open Virtual Keyboard on "CTRL+ALT+SHIFT+P"
    • if you want to disable quick access to Virtual Keyboard by pressing the keycombination, clear the box Open Virtual Keyboard on "CTRL+ALT+SHIFT+P"
  6. on the Settings window, click the OK button
  7. close the main application window.
Aug 21, 2014 | Computers & Internet
I have Kaspersky Security and firefox on my computer. I have had frequent issues with tryinhg to keep adobe flash player working..I have unistalled and reinstalled mulitple times..it will work for a
If you are facing problem in Adobe flash player, then it might be due to Kaspersky Internet security. Un-install kaspersky or disable kaspersky while viewing multimedia content.
If problem still occurs then use system utility tool Reginout for an instant fix.
Dec 02, 2012 | Adobe Systems Adobe Flash Player
We transfered our photos from our camera to a memory stick, using our Asus comupter, which has Kaspersky Antivirus 2011. When we then reattached our memory stick to try to view the photos, Kaspersky popped...
Sounds like your Kapersky Antivirus is trying to scan your memory sticks for viruses. Your memory stick is brand new so this isn't necessary. There should be an option to disable this? When Kapersky pops up, is there a button such as "Cancel" or "Disable" or "Settings"?
Aug 20, 2011 | Computers & Internet
I can not up date my antvirius
Settings->Update->Settings->Source->Add
there write in the source field: http://dnl-eu3.kaspersky-lab.com ->OK and then activate only the checkbox before the new field (disable Kaspersky Lab's update servers)
Nov 30, 2010 | Kaspersky Labs Kaspersky Internet Security...
Im using kaspersky antivirus 2009 and need help
Disable Kaspersky Antivirus & use a data recovery program to recover the photos. One of the best freeware data recovery program is Restoration.
You can download it at the following link: http://www.snapfiles.com/get/restoration.html
Dec 20, 2009 | Kaspersky Labs Kaspersky AntiVirus 2009 -...
Cannot activate kaspersky internet security 2010 ...... when i try to activate i get the error "Activation error : Server name cannot be resolved"... I can go to the activation.kaspersky.com but cannot...
This either seems to be a problem with a firewall or a virus itself. Here are the steps
1) Try to see if your firewall is blocking this. Go into Kaspersky and disable the firewall. Also go to Control Panel and check if Windows Firewall is still active. If it is, disable that too ... try again to activate.
2) Download the MalwareBytes anti-malware program on your computer and run a standard scan. If anythig is found, delete it and try again.
Nov 06, 2009 | Kaspersky Labs Kaspersky Internet Security...
How do i turn off Kaspersky lab to install 2009 security?
Windows Security center is not really useful, and is known to have issues sometimes detecting anti-viruses. Kaspersky suggests that you disable notifications.
To do this,
1. Click Start and then click Control Panel.
2. Double-click Security Center.
3. In the Security Center, under Resources, click Change the way Security Center alerts me.
4. In the Alert Settings dialog box, clear the Virus Protection check box, and then click OK. Thanks for using fixya....
Sep 15, 2009 | Kaspersky Labs Internet Security 2009 Full...
Proxy host error BSOD on PH32DSP.dll
Many Windows 7 users are facing BSOD (Blue screen of Death) error.
Follow the below steps to resolve the error.
1. Startup in safe mode (tap the F8 key on your keyboard repeatedly as the computer is starting up)
2. Select a method of safe booting from the menu (first try with networking; if the crash still occurs, try without networking)
3. Once the system has booted, click the Start button and type MSCONFIG then press enter in Windows Vista (in Windows XP, click the Start button, then click “Run” and type MSCONFIG then press enter).
4. Go to the Startup tab.
5. Disable Kaspersky and any related items (e.g. kl1.sys), then press OK, then restart the system if it does not happen automatically. Startup normally (i.e. not in safe mode).
Alternatively you can launch the Kaspersky application and set it to not start at startup.
Aug 03, 2009 | Funk Software Computers & Internet
I have a problem in opening tally 7.2 after installing kaspersky, anyone can please give me the solution
LET YOUR KASPERSKY ALLOW EXECUTING THIS PROGRAM
CLIC ON THE ICON OF KASPERSKY THE CLIC ON APPLIWATIONS UNDER CONTROLE LOOK FOR YOUR FOST THEN WRITE WLIC ON IT AND CHOOSE ALLOW
PLZ RATE IT FIXYA IF ITS HELPFUL
Jun 08, 2009 | Kaspersky Labs Internet Security 7.0 Full...
Install Kaspersky
Hi. Go to this web page:
http://www.avg.com/download-tools
and download and run the "AVG Remover". After restarting the computer, install Kaspersky.
Jan 27, 2009 | Computers & Internet
Computers & Internet Logo
377 people viewed this question
David Payne
David Payne
