When you pick up the horn and press the '0' key. The device chooses line 002. But line 002 is not connected. How can I change this, so when i pick up the horn and press 0, it chooses line 005 so i can dial the telephone number. Thanks in advance
SOURCE: Panasonic KX-T7633 Corded
Your system clock is displayed on all phones - so your system's time is off. If you have Caller ID, you can have the system set to adjust the clock daily according to Caller ID, but that often gets worse, depending on the telephone company. I've even seen some systems off by four hours or more, so we don't recommend that either.
If you have programming access to the system, the system clock is setting 000.
Our servers adjust the clocks automatically every weekend to the accuracy of the Naval Observatory's Atomic Clock.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
SOURCE: How do I transfer a call directly to voicemail?
If it's a Panasonic voice mail system you program a button for VoicemailTRansfer. Pick an unused button and label it VTR. Now, you need to know what the access number is for voice mail. It's usually 165 or 500. Then you press PROG the button and dial 94+ whatever number VM is and ENTER.
On the original installation, your installer should have at least given you 2 buttons, one for record and one for transfer. We usually give the customer a 3rd button called 2-way transfer. If your system is a TVA, there is a patch to record conversations as new messages, and if you have the optional LAN card(on the 50, it's already in the 200) for voice mail to email, it can send out the wav file at the end of the call.
Carl
SOURCE: changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
SOURCE: panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
