Question about Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum
Noise My Dyson DC08 is making a loud, rough, vibration/noise that seems to be coming from the from the rotating brush housing. I replaced the old belt which was several years old and slipping. When I run the motor with the new belt removed the machine sounds normal. The bearings on the rotating brush seem to be running smoothly when turned by hand both when out of the brush holder and when installed in the machine. I can't find anything rubbing on the belt or rotating brush. I applied a bit of WD40 to the brush bearings to see if it would make any difference, but it didn't. Any clues?
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson vacuum. From your description, it sounds like the model number you've supplied may not be correct, as DC08 is a cylinder vacuum which doesn't use a belt-driven brush bar. So we can confirm exactly which model you own and take you through some quick diagnostic checks, I'd encourage you to contact us directly. You can reach our experts by calling 0800 298 0298 (UK), or 1-866-693-9766 (US).
We'll look forward to hearing from you.
Best wishes,
Jack - Dyson Official Online Customer Surpport
http://www.dyson.com
Posted on Jul 04, 2013
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Posted on Jan 24, 2009
ukvacfan
  • 328 Answers
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Posted on Apr 02, 2009
  • 61 Answers
SOURCE: Dyson Animal DC14 brush will not rotate. Removed
If this model takes a clutch then it is stripped and needs to be replaced.
Posted on Apr 15, 2009
  • 58 Answers
SOURCE: brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
Posted on May 29, 2009
  • 143 Answers
SOURCE: Hello. My dyson dc04 keeps making a loud screeching noise.
remove base cover by 3 'screws' 1/2 turn anti clockwise and clean well remove fibres replace cover and re try.
Posted on Sep 14, 2009
My Hoover makes louder noise when the brushroll is on. I just cleaned but no result.
What kind of Hoover is this? There are a few things that will cause excessive noise and vibration such as a worn belt, the wrong belt, damaged end caps, damaged brush roll housing and worn bearings. Inspect the brush roll area. Remove the belt, if you have a spare, check the size. If it's more than 6 months old, replace the belt. Spin the brush roll in the housing, does it spin free or hesitate or not turn at all? If it spins with effort there could be debris under the end caps; if one end cap will not turn there is enough debris to cause the end cap to internally melt to the roller. If you cannot turn the brush roll by hand, replacement is your best solution. You should also inspect the housing where the roller spins, specifically where the end caps sit; look for damage to the slots in the plastic, it the roller will not sit snug this could cause enough vibration to make the sound you're hearing.
Sep 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Just purchased a reconditioned model. Makes a ton of noise and the bottom brush doesn't seem to turn like in my old Oreck. Does that indicate it needs a new belt?
Your Dyson does have a belt but its one that cant be replaced it is called a clutch assy. if your roller brush isnt spinning then it could be that you dont have the purple knob on the left hand side if your facing the vacuum to the carpet setting. if you do have it on the carpet setting and its still not spinning then your clutch need to be replaced.
dyson roller brushes donot rotate as fast as Oreck roller brushes. in fact they are rotate at about half the speed. so keep that in mind.
Apr 17, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson is making a loud scweeky noise
www.sewvac.com Remove the bottom plate and disconnect the belt.If it still makes the noise it is the lower motor that drives the brush that is bad.If it dosent make the noise try cleaning off the hair and debris from the motor pully and replace the belt you will need to take the brush out to do this.While the brush is out check the ends for binding they should turn smoothly with very little resistance also check the area the belt rides on the brush and make sure there is no dirt buildup in the area the cogs of the belt ride in. If it is the lower motor and is less than 5 years old call Dyson and they will generate a work order for a service provider.It may very well be under warranty. !-866-693-9766
Jan 28, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson Animal has good suction and works fine for actually picking up dirt, but when I use the vacuum with the roller, I hear a grinding/rumbling noise. Its only when I use the vacuum with the brush...
Trace the path of the suction into the tank and see if there is anything loose or ingested. Also, remove the brush and clean as best you can. Perhaps there is something caught in it. Lubricate where it makes sense with some WD40.
Oct 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson D17 is making an incredibly loud noise, like grinding, when the bottom brush rotates.
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Aug 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush bar does not turn & makes a loud noise
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vibrates very loudly when brush starts spinning
take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Apr 23, 2009 | Vacuums
Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum Logo
162 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
