Question about Hasbro Playskool Busy Gears
Playskool busy gears
Where can I get replacement gears for the busy gear toy
SAMSUNG Gear Watch not switching ON
try pressing the power button for 3 to 5 secs. If still no power, connect it to a working usb/power source and try to turn on again.
If no sign of power even connected, you might need a battery replacement. A little history on what happened before this will be helpful
Feb 11, 2015 | Samsung Galaxy Gear Unisex Jet Black...
My galaxy gear wont charge
Seems like the charging capabilities of the battery have been exhausted.
Try another cable/ac adapter. If same results, you might think of a possible battery replacement
Dec 03, 2014 | Samsung Galaxy Gear Smartwatch- Retail...
My kennith cole watch skipping a beat on the 5th second. And everytime I set time It lacks behind
Watches with a low battery sometimes are programmed to skip and then double a pulse to get your attention. So, you might see the second hand of your watch pulse every 2 or even every 5 seconds, making bigger than expected moves on your dial. In each of these situations, though, your watch should still be keeping time overall.
The situation that you describe sounds more like you either have a defective gear somewhere in your movement, or, equally likely, you have a bit of dirt hat is gumming up one particular tooth on a gear somewhere in your movement.
On a mechanical watch, the usual solution is to service the movement, disassembling the gear train and washing the gears in a special cleaning solution. Each gear would then be inspected for imperfections and either honed or replaced so that the movement as a whole worked properly again. Unfortunately, very few battery-powered quartz watches are designed for this type of service. A watch repair service can try to run your watch at high speed using a special test rig to see whether that flings out any dirt. They can also inspect the watch movement, though the amounts of dust and dirt we're talking about can be too small to be easily spotted.
Bottom line advice: try replacing the battery to see whether that makes a difference. If it doesn't, there's a decent chance that you'll be in the market for a new watch.
Apr 27, 2012 | Watches
Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
Jul 17, 2010 | Swatch Irony watch
Train blockage
mcdevito75 here, In laymans terms yes, it sounds correct, there are a series of gears between the main spring and Balance assembly (hairspring) These series of gears control the movement of the hands, and release of the mainspring, they are called a gear train, the shafts that hold these gears in place get oiled, when the oil gets old it"ll dry up, thus takeing up the space these gears (shafts) need to operate the gear train, thus makeing the watch Fast / Slow. Cleaning and oiling restores the proper movement to the gear train of the watch, the tech. will also check and regulate (Time) your watch.
Jul 14, 2010 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
My casio marine gear is 6 months old and started losing 5 minutes. what can I do?
Speak to your local Casio dealer, it could be that the battery needs replacing, (some watches can need replacements if they have power hungry features which have been used frequently.
If this is not the case, then if there is anything wrong with the watch, then it should be repaired under warranty.
Mar 01, 2010 | Casio Marine Gear AMW320D9EV Wrist Watch
My husband's watch won't keep time. We have had the battery replaced, so we know it is not that. it worked fine when we first got it. now, after only a few months, the time gets off.
Ther must be some kind of friction/resistance in the final drive ie the hands down to the drive gears. A new battery may temporarily show correct time but will quickly drain under these conditions It may clear over time but if it is new it should be replaced. If you cannot replace it try freeing the hands/gears by manualy turning the hands a few days forward
Aug 03, 2009 | Watches
Hasbro Playskool Busy Gears Logo
57 people viewed this question
Top Hasbro Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Hasbro Watch Expert? Answer questions, earn points and help others
