Hp color laserjet cp1518ni streak on right side of paper
SOURCE: STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
  • 214 Answers
SOURCE: HP Laserjet 4650 color printing problem
More than likely you need new drum.
Posted on May 06, 2009
SOURCE: HP Color Laserjet 2600n. Magenta color
This has become a common issue on these machines - due to design two laser-to-drum mirrors in the laser/scanner assembly face upwards. Because the unit is not sealed, the upward facing mirrors are a nice place for toner dust to settle.
The repair is rather easy for a trained professional - in theory anyone with the right set of instructions could perform the procedure, but I'd highly recommend a novice not try.
Instead call a trusted computer repair shop and explain the situation and that you need to have the mirrors in your laser/scanner assembly cleaned to resolve issues with faded color output. A reputable service agency with experience in HP printer repair should have no problem doing this procedure in less than an hour – so they shouldn’t charge you for more than an hour or two of bench labor. If the repair facility you contact doesn’t understand your request or tries to blame your toner cartridge; hang up and call another company.
Posted on Aug 03, 2009
  • 7 Answers
SOURCE: How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Posted on Oct 09, 2009
  • 990 Answers
SOURCE: streaks on my laserjet 3800
Hello sir; Remove the transfer belt unit, at the end of the unit you sill find cleaning unit, vaccunm it up, if neccesary, replace cleaning blade .
Posted on Oct 21, 2009
My laser color HP cp1515n is not copy anything that's black copy? what can l do
Hi there, my name is Lisa and I'd be happy to help you with your LaserJet CP1515n. The following document will help you to troubleshoot the issue you have described:
HP Color LaserJet CP1215 CP1217 CP1514n CP1515n and CP1518ni Printers One...
I took a second look and found this one too:
HP Color LaserJet CP1514n CP1515n and CP1518ni Printers Resolving Print...
I hope this helps.
I work on behalf of HP.
Jun 19, 2015 | HP LaserJet CP1515n Printer
Streaks paper laserjet
Due to faulty cartridge streaks appearing on paper/ITB. Take 4 cartridges out,check each cartridge drum surface for streaks,replace the faulty cartridge/s..
Sep 17, 2013 | HP LaserJet 4650 Color Printer
My HP Color LaserJet CP 1215 printer started haveing blue streaks on the left of the paper and black on the right. What is this?
you can try replacing the blue and black toner cartridges for your printer, they could be leaking. Also sometimes the toner powder just gets on the rollers that feed the paper, if you can remove the rollers and see if there is toner dust on them, you may be able to clean (and dry) them and see if the streaks go away.
Those are the simplest things to try, anything else would be a more complicated issue that you may want to have someone technical look at. But try the easy things first.
Mar 10, 2011 | HP LaserJet CP1215 Color Printer
Really bad copies
Check your toner levels. If OK Restore default settings on Printer
Jul 30, 2010 | HP Color LaserJet 2600n Printer
Printer streaks on card stock
adjust your thickness guage as card stock is 3 or 4 times thicker than a 20lb plain paper stock. Here is link to a helpful media guide for HP printers.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
Jan 30, 2010 | HP Color LaserJet 2600n Printer
Apr 16, 2009 | HP LaserJet 1020 Printer
I have black streaks on my copy
Before you installed the cartridge was it in the box standing on end, If so remove the cartridge from the printer and gently shake the cartrige from side to side then reinstall, the toner may be packed mostly on the one side.
Feb 17, 2009 | HP Color LaserJet 2600n Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
53 people viewed this question
k24674
jasbo
jasbo
