Question about Toshiba 43H70 43" Rear Projection Television
Univeral remote code for Toshiba 43h70
Can't seem to st up the remote that came with my new fiber service. none of the toshiba codes will turn on the unit. Many will tun off.
Try 0156 code
Posted on Oct 12, 2007
SOURCE:
My RCA Univeral remote will not program my Toshiba VCR. The remote works on other machines. What is the problem?
You need to be certain you are entering the correct code for the Toshiba. In your code book try them all for that brand. If it still doesn't work, it might be there's a problem with the remote sensor or detection circuit of the VCR.
If you don't have the codes/book post another question on here asking for Toshiba VCR Remote Codes.
Sep 09, 2010 | Toshiba Televison & Video
Tip
Toshiba 43H70 Service Manual Download
Download Toshiba 43H70 Projection Television Service Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 43H70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 43H70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 43H70 Projection Television troubleshooting & repair instructions.
I hope that helps.
_______________________________________________
Toshiba 43H70 Manual Download
on May 10, 2010 | Televison & Video
Tip
Download Toshiba 43H70 Projection Television Manual
Have you misplaced your Toshiba 43H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 43H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 43H70 Projection Television instructions.
I hope that helps.
How do I get a code to activate a univeral remote with a toshiba DVD player
I would suggest calling the manufacture of the universal remote or your local cable/satellite provider. One of the two should be able to provide remote code.
Oct 11, 2009 | Toshiba SD-K760 DVD Player
Need rca univeral remote code for a toshiba tv
1. Manually turn on the component you want the remote
to control.
2. Press and hold the component key (TV, DVD•VCR, AUX, SAT•CBL) you wish to program. The LED INDICATOR turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the LED INDICATOR blinks four times, and the process is exited.
3. While holding down the component key, enter the four-digit code. While you are pressing the numbers, the LED INDICATOR turns off.
4. After the fourth number is entered, the LED INDICATOR turns on. At this time, release the component key. If the LED INDICATOR turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry.
If the LED INDICATOR blinks four times when the component key is released, This means that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2.
RCA Toshiba 3 digit codes. 000,018,021,023,048,049,071,072,073,085,...
RCA Toshiba 4 digit codes.1000,1048,1072,1105, 1109, 1118,1160,1190,1241 Good Luck
Jun 14, 2009 | Televison & Video
Tip
Follow this link
I hope that helps.
on May 10, 2010 | Toshiba 43H70 43" Rear Projection...
Tip
I hope that helps.
Need remote control code for Univeral Remote.
For clarification pf the problem, may I know what exactly the brand and model of the remote you are intended to use on your recorder and tv.
Update me again here
Jun 04, 2009 | Televison & Video
Need codes for comcast reamote for this tvtoshiba projiection
most l ikely code is 11256 for comcast remote with toshiba tv
Mar 21, 2009 | Toshiba 43H70 43" Rear Projection...
Code for Toshiba HD-2A
Try this site -> http://www22.verizon.com/ResidentialHelp/FiOSTV/Remote+Controls/SetUp/QuestionsOne/84901.htm
Jan 08, 2007 | Motorola Mobility DRC800 Universal Remote...
Toshiba 43H70 43" Rear Projection Television Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
