The touch screen on my Konica Minolta Bizhub 200 does not sense touch while in copy mode. However, if I press the Enlarge Display button and go into that mode the touch screen works fine. There seems to be a software switch turning off the touchscreen in copy mode. How can I reset it?
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
