Question about GE JKP15 Electric Single Oven
Control Panel All the display fields in the control panel light are lit and I cannot get a response from any of the touchpad buttons. The oven is 8 years old and the control panel was replaced about 2 years ago after getting the F7 error. - I have tried the fix you ascribed to the F7 error by placing paper between the ribbon and housing, but that had no affect. - The power has been turned off and on to the oven several times, but the display always comes up the same. - I unplugged the ribbon from its holder and wiped it, but still the same problem. Is there something else to try or do I need another control panel, control module, or a new oven? Thanks!
  • Jimmy Roper Aug 07, 2007
    When I unplugged the control panel, the lights were still on. I assume the problem is with the electronic control module, so I ordered a new one.
How do you replace the control panel? My GE JTP15 has exactly the same problem.
Posted on Oct 20, 2007
  • 68 Answers
If the ribbon cable has two sections, try placing the slip of paper between the sections and down into the slot as far as possible. Other wise try removing the connector. If the displays clears up, the problem is in the touchpanel. If it doesn't, the problem is in the electronic control module.
Posted on Aug 06, 2007
  • 159 Answers
There is no other way to get around that but to replae the control once agsin. It sounds like there are some stuck touchpads or the control itself is shorted. either way you need to replace it.
Have a Whirlpool Gold dbl. oven. Last Fri. night oven started beeping and display the E0F2 code. Turned off brk'r till next a.m., turned on only to have in a rolling sequence going from 350 upper oven...
Good Evening!
Do you have the full model number of your appliance? Do all of the buttons beep when pressed? If not, unfortunately, the touchpad on your unit may have failed again. An E0-F2 is a stuck key error. The only way to fix this issue would be to replace your touchpad. Your more than welcome to send in your touchpad and control board for evaluation and testing. Contact us for more information We also have replacement touchpads for your oven if the original OEM part is discontinued.
Ledgestone Technologies Keypad and Ribbon Cable Installation
May 25, 2017 | Whirlpool GBD277PD Electric Double Oven
My stove keeps beeping and showing F1-8 on the display and telling me to call a tech. What is the problem. This slide in stove is abou 6 years old.
The F1-8 error code means that a button on the touchpad is stuck in and the touchpad needs to be replaced. The computer runs a self check on the oven several times per hour and it thinks a button on the touchpad has malfunctioned. Depending on your exact model the touchpad is a seperate peice or it has been intergrated into the control panel, so if it's seperate only it needs to be replace,if it's intergrated the whole control board needs to be replaced.
Hope this helps ya
Aug 01, 2011 | Jenn-Air Ovens
We have a maytag oven. all the buttons work except for the bake and light button.Mod # umc5200aaw
only half of one side of the maytag oven touchpad control panel works, its one 2 yrs old help!
Jul 06, 2011 | Maytag 30 in. Electric Single Wall Oven...
F1 is popping up on my digital display and a beeping noise comes along with it. What does that mean and how do I get it to stop?
Your F1 error is
: indicating an electronic control malfunction
: (a $250 part) or a control panel (a $60
: part)? Usually if the symptoms stop with the touchpad disconnected from the clock, that touchpad is often the cause. If the error continues even with the touchpad disconnected, the clock itself is usually at fault and will need to be replaced to correct the problem. On some models it is not possible to disconnect the two in which case the electronic control/clock would have to be replaced regardless.
There is a tool that allows testing of the touchpad (on models where they're separate parts) but is kind of expensive for a homeowner to purchase them self. If you contact a technician so equipped, they should be able to test the touchpad before replacing any parts.
BTW. On most models, the control keypad is only sold along with the whole control panel (without the electronic control) but on some models the keypad linked below can be used to repair the one on the original control panel.
Apr 19, 2010 | Magic Chef 9122 Gas Single Oven
I have a Whirlpool RBD275PDS14 double oven. It
Look for a blown fuse mounted on back of the controleb59c28.pngtis page is in the MANUAL
Feb 10, 2010 | Whirlpool RBD305PD Electric Double Oven
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
LGR3330ADB Admiral touchpad display does not work
Usually this is due to a bad main clock/electronic control in the control panel but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru ---
Jan 27, 2009 | Ovens
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
May 15, 2008 | Whirlpool RBD275PD Electric Double Oven
GE JKP15 Electric Single Oven Logo
238 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
