Question about Refrigerators
Model 47SLC-LH-MFG. Seriel number 84553. Cold tech freezer, blue and white. How do you remove slider doors to clean?
  • 62 Answers
SOURCE: Freezer works but fridge does not cool..please help
Ther are several things that can cause this, one a bad evaparator fan or an defrost problem. Look on the back of the freezer wall and see if there is a lot of frost. If there is then it's a defrost problem and the part most likely is a bad termination thermostat also known as a bi-metal. If there is not a lot of frost, check to see that you have air going to the refrigerator section. If not then it could be the fan.
Posted on Aug 30, 2008
rockitman187
  • 2559 Answers
SOURCE: freezer works but frig is not cold
That could be it.
Posted on Jul 16, 2009
  • 7 Answers
SOURCE: 17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
Posted on Aug 15, 2009
SOURCE: Cleaned behind and under the frig and now it won't work
Don't know if this a solution or not. We must have moved something or jarred something when we vacuumed inside the back. After we moved it out again, took the grill off the bottom in the front, cleaned it and put it back on, everthing seemed to work OK. We went to work that morning and when I got home in the afternoon, the freezer and fridge were both working fine.
Posted on Dec 16, 2009
heatman101
  • 43501 Answers
SOURCE: -fridge not cooling, freezer frosting
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 08, 2010
The freezer has a white plastic back panel with vents to blow the cold air into drawers. That thing pulled away (ice formed behind it) - how to put it back?
there is some ice that has frozen the door in a fixed potion, if you have hair dry put on warm point toward where it hinges other than that call some service person to help you.
you mite call the manufacture customer service dept. ask for service
technician, explain whats wrong and see what they say. it never a bad question, or to ask for help!!
www.ask.com/mfg.name/make/model/customer/service/telephone#/
Oct 06, 2015 | Refrigerators
Oven door spring model av 669 26a
MFG Part Number:WB9K4 if spring is red -MFG Number WB9K5 if spring is black with a spot of blue paint. To access the spring remove the storage drawer. One end attaches to the hinge the other to a slotted hook. Check the opp. side spring to see how it is hooked up.
Feb 05, 2013 | Tappan TGF364AS Gas Kitchen Range
Frigadaire temp light will not go off but still cold
Do not know if you mean the cavity light or the power indicator light at the outside bottom of the door. The power light is always on when there is power to the unit. it could be red or green. The light switch could be shorted closed or open depening on the MFG design. Rare but can happen, ground short through light wiring. Access / remove light switch, remove one of the wires. If the light goes out...the switch is bad. If possible and you have a multimeter and know how to use it. Remove both switch wires and with unit unplugged measure resistance to ground. open - zero through load L1, continuity through neutral. Plugged in 120v between load L1 & ground, zero volts between Neutral & ground. Keep bulb in receptical. Call qualified tech is not sure how to use tools to test.
Mar 28, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Need a manual cold tech 47slc-lh-td
need more info , you ask for access , then said you pulled it.
Mar 22, 2012 | Cars & Trucks
Cooling quit suddenly in both freezer and fridge side. Pulled out unit and sounds like compressor is running and compressor fan (across coils) is running. Circulation fan in freezer is not running....
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Frigidaire FRS6R5EMB Side by Side...
The freezer side quit staying cold today. No
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Dec 14, 2009 | Amana Refrigerators
The freezer side is frosting other side is not reminding not cold
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Oct 26, 2009 | Refrigerators
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
