Question about Saws
50s 1 how do i install gaurd return spring
    Novelist:
  • 99 Answers
Remove the blade, and you will normally see a hole in a lug on the inner ring of the guard and a slot with a bar across it on the upper inside of the fixed guard. Either end of the spring will hook through these. Sometimes (normally on DeWalt) the springs will be attached with a small self tapping screw with a washer at either end.
Posted on May 05, 2013
How dose the line return spring install can't really tell how to install it please jelp
nstallation of Wolff trigger return spring??? - The Firing Line ...
https://thefiringline.com/forums/showthread.php?t=132371
Sep 28, 2002 - 10 posts - ‎4 authors
I know how to install the main spring. How do you install the trigger return springthough? I'm asking cause I just ordered the Wolff GP 100 ... GP100 - Hammer/Trigger Spring Questions
Aug 8, 2012
Changing Springs in SP101
Apr 8, 2011
Wolff replacement main spring for S&W?
Apr 6, 2011
Show of hands...CZ trigger return spring
Feb 19, 2007
More results from thefiringline.com
Nov 02, 2015 | Cars & Trucks
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
Diagram for parking brake cables
  1. For the 1500HD, relieve the tension from the park brake cable by pulling down on the park brake cable in front of the equalizer then removing the cable from the equalizer bar.
  2. For the 25/35 series Disable the park brake cable automatic adjuster.
  3. Raise and safely support the vehicle.
  4. Remove the tire and the wheel.
  5. Perform the following procedure to remove the cable (2) from the backing plate (4):
    • Compress the spring (3) by pushing toward the lever (1).
    • Depress the locking tabs.
    • Pull the cable housing out of the backing plate (4).
    • Remove the cable (2) through the slot in the backing plate.
      Lever (1), cable (2), spring (3) and backing plate (4)
  6. Remove the park brake cable (2) from the lever (1).
  7. Remove the rotor.
  8. Remove the rear axle shaft.
  9. Remove the park brake shoe return spring (6).
    Park brake shoe assembly 1500HD, 25 and 35 Series
    Click to Enlarge
  10. Remove the park brake shoe anchor springs and pins.
  11. Separate the tips of the shoes from the park brake actuator and remove the park brake shoes and adjuster assembly from the vehicle.
To install:
  1. Clean the debris and the dust from the park brake components using a clean shop cloth.
  2. Install the adjuster assembly to the park brake shoes.
  3. Separate the tips of the shoes and install the park brake shoes to the park brake actuator.
  4. Install the park brake shoe anchor springs and pins.
  5. Install the park brake shoe return spring (6).
  6. Adjust the park brake shoe.
  7. Install the rear axle shaft.
  8. Install the rotor.
  9. Install the park brake cable (2) to the lever (1).
  10. Perform the following procedure to install the cable (2) to the backing plate (4):
    • Compress the spring (3) by pushing towards the lever (1).
    • Route the cable (2) through the slot in the backing plate.
    • Push the cable housing into the backing plate (4) until the locking tabs snap into place.
  11. Install the tire and wheel.
  12. Remove the safety stands.
  13. Lower the vehicle.
  14. Enable the park brake cable automatic adjuster.
  15. For the 1500HD, install the park brake cable to the equalizer by pulling down on the park brake cable in front of the equalizer then installing the cable to the equalizer bar.
  16. Adjust the park brake cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 23; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos'; shinehutt_0.gif
Jan 13, 2011 | 1995 Ford F150 Styleside Regular Cab
Blade installation sequence
Push the yellow button on the right side of the blade gaurd there is a hex wrench under the grip handle that stores in the body with yellow butten depressed turn hex bolt clockwise ot lossen its a left handed thread so it dosen;t lossen during use remove bolt and washer raise blade gaurd remove blade when installing new blade note arrows printed on blade the saw rotates clockwise teeht face forward
Nov 22, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Parking brake cable stretched beyond adjustment how do you replace
Rear Brake Shoes- You'll need to know how to remove the rear brake shoes to remove the parking brake cable. REMOVAL AND INSTALLATION Amigo and Rodeo
  1. Raise and safely support the vehicle.
  2. Remove the rear wheels.
  3. Remove the brake drums.
  4. Remove the brake return springs.
  5. Remove the leading shoe holding pin and spring, and then the leading shoe.
  6. Remove the self-adjuster and the adjuster lever.
  7. Remove the trailing shoe holding pin and spring.
  8. Disconnect the parking brake cable from the trailing shoe and remove the trailing shoe. Remove the parking brake lever from the trailing shoe. To install:
  9. Attach the parking brake lever to the trailing shoe.
  10. Connect the parking brake cable to the parking brake lever.
  11. Apply a thin coat of high temperature grease to the shoe contact points on the brake backing plate (locations A and C in the accompanying illustration), piston contact surface (B), and self-adjuster (D). Fig. 1: Exploded view of the rear drum brakes — Amigo and Rodeo 93026g56.gif
  12. Position the trailing shoe on the backing plate and install the hold-down pin, spring, and retainer. Don't stretch the return spring when fitting the shoes onto the backing plate.
  13. Connect the upper return spring and the leading shoe to the trailing shoe and position the leading brake shoe on the backing plate.
  14. Install the adjuster assembly and the hold-down pin, spring, and retainer.
  15. Use a brake spring tool to install the lower return spring.
  16. Install the self-adjuster lever and adjuster spring.
  17. Adjust the shoe-to-drum clearance to 0.0098–0.0157 in. (0.25–0.40mm) and install the brake drum.
  18. Check the brake drum for scoring or other wear. Machine or replace as necessary. Check the maximum brake drum diameter specification when machining.
  19. Install the rear wheels. Lower the vehicle.
  20. Road-test the vehicle.
Aug 17, 2010 | 1997 Isuzu Rodeo
Don't know how to attach the vacume
The discharge tube and collector bag will replace the blower nozel ( where the air comes out when blowing). The large diameter tube ( pick up tube) will attatch to the impeller side. There is a plastic gaurd on a spring loaded hinge. Open the gaurd and attatch the large tube.
Nov 28, 2009 | Poulan & Vacuum Kit Attachment
How do you get the deck belt back on the pulleys? 20 hp-46'' deck
It helps to remove the belt gaurd on the left side of the deck. The belt gaurd on the drive pulley ( motor crank) can be pulled out and moved by hand- lay on left side of mower and reach across and pull right side of belt gaurd from hole in frame and swivel away. Once belt is installed slide gaurd back into hole. all other pulleys the belt can just be spun on past the gaurds. Be sure to replace all belt gaurds and saftey devices as they came from the factory.
Nov 24, 2009 | Mtd Garden
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
Remove and replace rear brake shoes on 2004 honda accord
  2. Remove rear wheel assemblies.
  3. Release parking brake.
  4. Remove brake drum.
Rear brake shoe assembly
  1. Using an appropriate brake spring tool, unhook upper return spring from rearward brake shoe.
  2. Push retainer springs IN and turn to remove tension pins.
  3. Lower brake shoe assembly and remove lower return spring.
  4. Remove brake shoe assembly from back plate.
  5. Disconnect parking brake cable from lever and remove brake shoe.
  6. Remove parking brake lever from brake shoe.
To Install:
  1. Install parking brake lever to rearward brake shoe.
  2. Secure lever to brake show with a NEW U-clip.
  3. Pinch U-clip closed.
  4. Connect parking brake cable to rearward brake shoe.
  5. Install self-adjuster lever spring on front brake shoe.
  6. Assemble clevises, adjuster bolt and upper and lower return springs.
  7. Apply a light coat of grease (Molykote 44MA or equivalent) to sliding surfaces.
  8. Install brake shoe assembly onto back plate.
  9. Install tension springs.
  10. Using an appropriate brake spring tool, unhook upper return spring to rearward brake shoe.
  11. Install brake drum.
  12. Install rear wheel assembly.
  13. Lower vehicle.
  14. Adjust self-adjusting brakes by pressing brake pedal several times.
Jul 13, 2009 | 2004 Honda Accord
Changing rear drum brakes ona 1999 chevy dually
INSTALLATION PROCEDURE
  1. Install the parking brake lever (2).
  2. Install the spring washer (3). The concave side of the spring washer should face the parking brake lever.
  3. Install the pin (4).
  4. Install the retaining ring (16).
  5. Install the adjuster pin (12) in the shoe (15) so the pin projects 6.8 to 7.0 mm (0.268 to 0.276 inch) from the side of the shoe web where the adjuster actuator is installed.
  6. Apply brake lubricant or equivalent to the threads of the adjuster screw (14) and inside diameter and face of the socket (7). Adequate lubrication is achieved when there is a continuous bead of lubricant at the open end of the adjuster nut (10) and the socket (7) when the threads are fully engaged.
  7. Install the upper return spring (5).
    • Lay the shoes (1 and 15) on a clean, flat work surface in the position they will be in when installed on the backing plate.
    • The shoe with the parking brake lever goes to the rear of the vehicle.
NOTICE: Do not over-stretch the upper return spring. Damage can occur if it is stretched to more than 204.2 mm (8.04 inches) .
  1. Install the adjusting screw assembly.
  1. Lubricate the shoe pads on the backing plate with a thin coat of white lithium grease.
  2. Install the shoe and lining assemblies (1 and 15).
  3. Install the upper return spring (5).
  4. Install the adjusting screw assembly.
    • Do not damage the wheel cylinder boots.
    • Overlap the bottoms of the shoes so the upper shoe ends clear the wheel cylinder boots.
    • Make sure the upper shoe ends rest on the wheel cylinder piston ends.
    • Do not place the lower shoe web ends under the anchor plate until the lower return spring is installed.
NOTICE: Do not over-stretch the lower return spring. Damage can occur if it is stretched to more than 107.3 mm (4.22 inches) .
  1. Install the lower return spring (6).
    • Bring the ends of the shoe and lining assemblies (1 and 15) together over the anchor plate.
    • Hook the spring ends to the shoe web holes.
    • Spread the lower ends of the shoe and the lining assemblies to clear the anchor plate.
    • Position the shoes against the backing plate and release them.
    • Pull the spring into the groove at the bottom of the anchor plate.
  1. Connect the hold-down pins and the spring assemblies (8).
  2. Install the adjuster actuator (11) over the end of the adjuster pin (12) so the top leg engages the notch in the adjuster screw. NOTICE: Do not over-stretch the actuator spring. Damage can occur if it is stretched to more than 83 mm (3.27 inches) .
  3. Install the actuator spring (13). The free end of the adjuster actuator (11) must engage the notch of the adjuster nut.
  4. Connect the parking brake cable to the parking brake lever (2).
  5. Install the drum. Align the marks made during disassembly.
  6. Adjust the rear brakes.
  7. Install the tire and the wheel. Align the marks made during disassembly.
Jul 21, 2008 | 1999 Chevrolet 3500
Saws Logo
47 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
