Question about Pool & Spa
Need a manual and/or parts list for pump
This is an industrial impeller pump made and ordered from Germany. I have no idea where to get a manual for it. The serial number is JB-20050250-001 Any help would be appreciated.
  • charles urban Apr 26, 2013
    Sorry, i forgot to add those. Gusher model# Dn-125-250B-28-40HP-W/sms sn# JB-20050250-001
  • 7,482 Answers
We need more information that what you provided.
We need the following:
Manufacturer...Model Number...Serial Number before we can help find a manual for the motor
Bud
Posted on Apr 26, 2013
2 Suggested Answers
MOTORWIZJ
  • 1383 Answers
SOURCE: Hello, I have an
WELL HERE YA GO. I TAKE THE MOTOR COMPLETELY APART , TAKE THE ROTOR AND PLACE IT IN THE VICE , THAN I TAKE A BIG PAIR OF CAHNEL LOCK PLIERS AND BY GRIPPING THE OUT SIDE EDGE OF THE IMPELLER, TURN TO THE LEFT ! IT IN MOST CASES COMES OFF WITH EASE .. IF YOU DONT HAVE THE TOOLS, GET THE MOTOR DOWN TO THE ROTOR AND SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING .. AND I'M SURE HE WILL TAKE IT OFF FOR FREE FOR YA .. I'TS BEST OFF TO HAVE HIM DO IT, BECAUSE IF YOU BREAK THE IMPELLER , IT CAN COST YOU BIG ! .. IF I WAS OF HELP HIT THAT YES BUTTON .. THANKS ..JAY... THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA .. HOME OF THE BARK'N GOOD DEAL
Posted on Jun 20, 2011
How to separate motor from 1/2 HP sprinkler pump?
To do that you need to take the pump apart...take the bolts out that hold the motor to the pump and then unscrew the impeller from the pump shaft....
All this is not easy and will be very difficult if you are not experience and handy with your hands...
getting the impeller off in one piece can be the toughest part...
heatman101
May 10, 2011 | Sta Rite Industries Shallow Well Jet...
Where I can buy the A.O Smith 3/4 HP pool pump impeller?
You'll need information from the pump that the AOSmith electric motor is attached to in order to get an impeller or any other pump parts. If there is no nameplate for the pump are there numbers on the impeller you need?
John
Mar 03, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
My electric pump for my sprinklers system. It is an old Sears cemterfuge 2 ph motor. I imagine it's from the late 70's to mid 80's, with a cast iron pump housing. When the I turn it on it will not turn....
Hi, W/D here.
Sears doesn't make anything. The pump is probably made by Sta-Rite. I did a "Google" search for Sta-Rite and found a number of exploded diagrams, parts lists and the like. What I'd try first would be to remove the cap on the end of the motor (with the power disconnected) and try to roll the motor over by hand. If it will rotate, I'd change the motor start capacitor (available at your local appliance parts supply house), and try it again. This may save you $480 by investing $12. The symptoms you described are classic for a failed capacitor.
Check the "Google" search for a similar model, and then trace that back to a manual, or even look at the exploded diagrams for disassembly instructions. Without knowing more about your particular pump, I cannot say exactly how to proceed. This should give you a pretty good start though. I don't believe that I would change the impeller as they don't wear out too often. If the pump isn't putting up enough pressure or volume, I might consider it, after checking and adjusting the regulator. They fail more often than impellers. Bearings can also contribute to too many amps being pulled, but you would have heard them probably before they failed. If you do need new bearings, WW Grangier, McMaster/Carr, or Motion Industries are way less expensive than going through the pump vendor or having them ordered for you. If you have a local Motion Industries near you, try them first. Just a little free advise, learned the had way, by one who lived in the country for years and counted on his pump to work every day!
Best regards, --W/D--
Feb 20, 2011 | Garden
Polaris pb460, replaced the impeller and seal. motor binds when the impeller is threaded all the way.
This means that one of the 2 pieces of the shaft seal are not seated all the way. More likely the part on the seal plate. Make sure you use a non petroleum based lube to seat the shaft seal.
Dec 28, 2010 | Polaris Pb460 Polaris Booster Pump...
I have new impeller & seals for pb4-60 booster pump and need to know the orientation of ceramic/rubber seal should be inserted into impeller - rubber lip toward or away from threaded brass wijidigit?
Rubber toward the impeller,so when you screw the impeller back on the ceramic ant the graphite on the other half face each other. This is so the graphite wears smooth against the ceramic.
Nov 13, 2010 | Polaris Pb4 - 60 Booster Pump
I am having difficulty removing the impeller on my Polaris PB4 Booster pump. I removed the seal plate and held the motor and attempted to turn the impeller counterclockwise. Can't get the impeller to...
For an impeller really stuck on the motor shaft you need to pull the motor thru-bolts and remove the rotor with the pump still attached from the stator. Lock the rotor in a vice and turn the impeller off with a large set of channel locks or a large strap wrench.
John
Nov 07, 2010 | Polaris Pb460 Polaris Booster Pump...
How do I remove the pb460 booster pump in order to install the new one? Does the water have to be turned off from the pool?
You are trying to remove the pump so you can replace the impeller correct?
To remove the impeller you do not need to remove the whole pump. Turn off the electric first. Then just remove the several bolts and separate the back half from the front. Then disconnect the electrical from the motor and your can pull the motor with the seal plate, and impeller all the way out and work on it. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white and black ceramic surfaces 100% free of any dirt, grease, etc while working with them
Sep 17, 2010 | Polaris Pb460 Polaris Booster Pump...
Seals are leaking on my PB4-60 pump
o.k. we will call impeller front ok ? take back cover off look at end of shaft slot for screw driver? put screw driver in slot turn impeller off .
Jan 22, 2009 | Polaris Pb460 Polaris Booster Pump...
Pool & Spa Logo
53 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
