Question about Kenmore 43142 Front Load Washer
Water leaking Hi. I bought a 1 1/2 year old Kenmore front loader from an estate sale. Seemed to work great in beginning, but now I am noticing a small puddle of water that seems to be coming from the bottom of the washer somewhere.I've only had it about 2 weeks. Please advise.
    Genius:
  • 2,985 Answers
Leaking pump or drain connexion most likely you will have to get under to check it out. Put a several sheet to news paper under the machine and pull it out as it stands to see where the water is coming from front/back/sides Do a wash and repeat. But you will need the service of an engineer I guess unless you are good with a wrench.
Posted on Aug 05, 2007
14 year old Whirlpool Estate washer. leaks small
Most likely you have a leaking water pump. This is not too hard to change if you are somewhat mechanically inclined it is around a 5 on a scale of 10. Your model # should be on the back of machine towards the top. If you want to change it yourself let me know and I will give you directions. Let me know if I can do anything else to help.
Mar 18, 2010 | Washing Machines
Hot water use on a cold /cold cycle
I bleive hot water in introducted @ begaining of cyle to disolve deterant call whirlpool 800 number .
Oct 26, 2009 | Kenmore 43142 Front Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Loader Washer Cold Water Intake problem
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Leaking front loader
the most likley place is the front rubber boot it can get a small hole in it and leak if the hole is not to large you can clean and dry it and reseal it with silicon rubber sealent
Dec 03, 2008 | Kenmore 44102 Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Kenmore 43142 Front Load Washer Logo
148 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
