Hanning washing machine pump dpo35-025
It seaze
What issues can I expect if it doesn't restart?
If the belt broke you are facing bent valves in the cylinder head. If the vehicle is single over head cam.... bet on bent valves. If the vehicle is dual over head cam ... you may be ok. The dealership should be able to perform a cylinder leak down test to determine whether or not the there is a valve issue before disassembling anything.
Mar 01, 2016 | 2007 Chrysler PT Cruiser Touring Hatchback
Mi lavadora funciona, pero cuando llega al ciclo de torcer hace un ruido como que golpea y parece que camina lavadora whirlpool w10250884
Hola '
Suena como los cojinetes en la parte trasera del tambor se han derrumbado.
Si el tambor est? suelto y ruidoso cuando se gira a mano significa que los rodamientos han desgastado.
Este es un gran trabajo y probablemente ser?a m?s barato comprar una nueva m?quina.
Buena suerte.
Nomess
Feb 24, 2015 | Whirlpool Washing Machines
What is the problem with a 1999 Mercury Sable that is over heating, losing water and the serpentine belt is not turning
belt tensioner is seazed or a pulley is seazed so belt wont turn or belt needs replacement as groves are worn out. the over heating could be your thermostat
Sep 17, 2013 | Mercury Sable Cars & Trucks
Water pump
sounds very much to me like water pump has seazed needs replacement water pump and welah also as well as a new thermostat to be sure
Jul 29, 2012 | 1997 Nissan Quest
How do i get a rim off that is seazed and preatty much looks like it welded itself onto the hub. it's a factory mercury mountaineer rim on a jeep grand cherakee.the center hole was too small. by t
Spray the area generously with penetrating oil. Let the air out of the tire jack it up as high as you can get it, block it up with some stands, Get a BFH and proceed to wail on it as you turn it. Try to hit the rim and not the tire. Have Fun!
Feb 10, 2012 | Cars & Trucks
I have an Admiral LNC6760B71 model and it just quit working (lost power). We checked the breaker and it was tripped so we fixed that and also plugged it into a different outlet just to be sure, but still...
A leading cause of that is the drain pump has seazed up.When it has seazed up the motor still trys to turn it but is having a real rough time,so it trys even hard to the point the motor overheats due to drawing excessive amprage where it ultimatly trips the circuit breaker.By getting to the back of washer if able and removing the small panel on right side and removing the clips that hold drain hose up to top of cabinet,the drain hose could be pulled through that small panel and holding it a low point the water in washer will drain by gravity, use a couple of buckets to catch water. After water is drained reinstall drain hose to where it normally goes,the washer could be tipped up so the control panel is resting on the wall, the drain pump will be on the right side,you could turn the pulley by hand and see if it turns easily,if any resistiiance or if the pulley doesn't turn at all,the pump& possible based on the condition of it the belt will need to be replaced.
I hope my answer will help you to resolve your washer trouble,
Gene
Aug 05, 2011 | Admiral Washing Machines
The car wont start ,the battery is fully charger,wont crank or turn
Is it a manual transmission model? If so, you might want to check the fuse activating the clutch-in start. Mine blew and all it takes is a simple fuse replacement :-)
Aug 16, 2010 | 1991 Honda Civic
Air conditioner blowing warm air in saturn ion
if the AC is blowing worm air you need to get your AC recharged if you have alredy done that you should get the compressor checked (it sometimes seazes up or the cluch on it will seaze and you will need to replace it
i hope this helps
Aug 06, 2010 | 2006 Saturn ION
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
