Question about Cub Cadet Garden
Adjust idle speed
I have a cub cadet 1210 hydro, I just replaced the ignition coil. I had to remove the carb and now that I have put it all back together the throttle is very very high to the point that I have to almost turn the throttle down to turtle speed so it sounds normal again. What am I doing wrong, please help?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 865 Answers
On the top of the carburator there should be an adjustment to set the idle speed
Posted on Jan 11, 2016
  • 246 Answers
SOURCE: new parts may not put wires back on wright
Hello clmcpeak:
>>You can View a Breakdown/IPL of this Unit at this Site Addy; http://www.jacobisalespartslookup.com/home.asp and Select the Cub Cadet Logo. Now Select Shop Online Parts Look Up. Now Select the OEM ( Cub Cadet) and Select the Model Tab. Then Enter the Model Numbers and Click Search. Then Double Click on your Model in the Results Area. Then Select Sectional View. Then Select the Section of the Unit you Wish to View. Select the Electrical File.
>>Most of these Breakdowns have a Schematic of the Electrical Systems of the Mower and Engine. If No Schematic of the Engine, then
Send me the Make, Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 59 Answers
SOURCE: Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Posted on Jun 27, 2009
  • 202 Answers
SOURCE: cadet does not fire
is it the 12 hp kohler? if so it is electronic type no points.
have you tried cleaning the flywheel magnet and coil?
use very fine sandpaper and clean them. if still no go gheck kill switch and nothing there is is probally a bad coil.
Posted on Jul 25, 2009
  • 110 Answers
SOURCE: 8hp Tecumseh engine how to adjust carb. when I put
These symptoms indicate a rich mixture. Assuming the carb is the original (and therefore correct) one, and that it has an adjustable main jet, turn in the main jet adjustment screw on the bottom of the float bowl until the engine runs smooth.
If there is no adjustment on the float bowl, the carb will have to be removed and properly cleaned (ultrasonic cleaner recommended).
Posted on Oct 01, 2009
  • 6468 Answers
SOURCE: Cub cadet lawn mower suddenly decreases power at full throttle
check the spring tension on the carb linkage
Posted on May 13, 2012
I have a Cub Cadet lt1045 the starter clicks up to try and turn the engine over but the engine is stuck. Any ideas on what it could be
I had a similar problem with my car. It turned out to be the starter motor was sticking. Put in gear and rocked it back and forward to move the pistons. Tried again to start and it worked. Eventually had to replace the starter.
I know yours isn't a car, but might be worth seeing if that works.
May 21, 2016 | Cub Cadet Garden
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
My 3204 quits running when it gets hot.
hi there
n9ove64
sounds like it may be a ignition unit going o/c when hot
will it restart when unit has cooled down ?
pay to check tank breather for blockage and check carb main jet for debris partial obstruction
before replacing coil
here is web site for parts
http://www.partstree.com/parts/?lc=cub_cadet&mn=3204+Tractor
go to ignition/ electrical parts section
part number for coil
Cub Cadet KH-24-584-45-S (replaces KH-24-584-01)
Module, Ignition
cheers pauly46
dont forget the thumbs rating
Jun 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cadet does not fire
Jul 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
The mower is a cub cadet it usually runs fine until warm and will die start idling up and down and then die every now and then pop like back firing.it will start right back if you lift the choke i changed...
I had the same problem , found out it was the coil was getting hot. I replaced the coil which was not hard , remove 2 screws an unhook 2 wires. You have to get the coil from a dealer , in my area anyway. Hope this helped.
Apr 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
148 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
