Question about Refrigerators
Fisher and paylal E442B.....water leaking from freezer and build up of ice on freezer floor, but freezing fine and not loss of temperature.....could it be the ducts are blocked? Where do I find them?
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Posted on Sep 19, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
  • 3 Answers
SOURCE: samsung twin door fridge water leaking onto floor
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The repair technician removed the trays and food from fridge, remove the screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He placed panel in sink and used something similar to a blow dryer with narrow hose on it to defrost both the panel and drain in fridge. Took him maybe 15 minutes and charged $99 total for the visit.
In future I will do this myself now that I know how but thought it may be useful information to others who are having similar problems.
Posted on Sep 08, 2010
peyton32034
  • 410 Answers
SOURCE: ice builds up on floor
most likely you have a plugged and frozen defrost drain. check behind the bottom basket of your freezer section to confirm this you will find alot of ice build up. to repair you self:
  • unplug refrig.
  • unload freezer section
  • remove rear access cover (on jenn-air's there are 2 screws about mid way up they are painted white and arent very obvious).
  • clear all ice
  • flush drain hole with warm water. ( i use a turkey baster filled with hot water to get best results)
  • reassemble unit
  • reapply power
this should stop your water leak. thanks Peyton
Posted on Oct 10, 2010
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
KFCS22EVMS leaked once made noise
Watch to see if 1) the water dispenser freezes 2) if you end up with ice build up. What you might have heard was a heater element pop. If that is what happened, then the cooling coils will freeze, no air will flow through the coils, and the freezer will not get very cold. If you can find a diagram of your unit, it may be worth taking a look to determine if the heater element is ok and/or if the cooling coils are packed with ice.
Oct 18, 2012 | Refrigerators
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
E442B Fridge is not cold & some ice build up in fridge. How do you remove the back of inside of freezer to check ice build up there?
don't mess about with it just remove items and get a new one sound like its leaked it's gas (BUT DON'T PANIC) its not harmful and its not going to blow up! you could call a engineer but a lot of the time your just as good putting that money towards a new one
your friendly domestic appliance engineer chris
Dec 05, 2011 | Refrigerators
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
F&P fridge not cooling and the freezer is icing up model E442B it isn't flashing codes
Check fan by removing and connecting to a 12v dc source. Ensure 12v is available at the plug situated on the fan baffle plate. Allow ice to thaw on lower condenser before replacing fan (replacment fan if necessary) Fan must recirculate air to freeze contents of freezer.
Mar 06, 2010 | Fisher and Paykel Active Smart E522B...
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Aug 25, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
