Question about Pioneer DEH-P4600 CD Player
DEH-P4600MP loses XM channels when car is turned off
I've had this problem for a few months now. I have XM radio and thoroughly enjoy using it. However, now whenever I turn the car off, and start it back up, the XM loses all the preset channels, and I can only receive channel 1. Whenever I select a new channel, i get a message that says 'updating' and it never finishes. Just to test it out, I updated XM and after I received all the channels, turned the car off. All the updated channels were gone, and I was back where I had started. I need to know what to do. Is it a problem with the head unit, or with XM, or with something else?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Re: DEH-P4600MP loses XM channels when car is turned off
When the rario turns off, it seems the XM receiver is losing memory power,check the wiring to be sure its present.
Posted on Aug 06, 2007
0 characters
3 Points
I have XM radio in my chevy malibu. Worked fine
I believe when the antenna loses power it does not show it on the screen sounds like there might be a break in the antenna wire or simply came out of socket in the rear of the radio.
Nov 03, 2009 | XM Radio (XMP6000)
Need wiring diagram for a deh-p4600mp
Feb 19, 2009 | Pioneer Car Audio Receivers
Alpine CDA-9856 not receiving XM radio
there should be a reset on the xm box itself if not the alpine has one on the face its a small button the size of a pen tip on the face or behind the face plate..this should do it
Nov 22, 2008 | Car Audio Receivers
Changing channels with XM radio
Push the button just to the right of present number 1 and this switches the setting between scan and scroll while in XM mode.
Jul 02, 2008 | Alpine CDA-9883 CD Player
XM Loading Problem for Volkswagen
I had the same issue. I called XM multiple time to have the signal resent. I told them I was receiving the preview channels and nothing else. I asked them multiple times if it could be hardware issue and they said no. I took it to the dealer and they ran a test ($98) and determined that the unit had failed. They didn't charge me for the $800 unit, but they did charge me $300 for the installation. Its working fine now.
May 26, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
Connecting XM radio to my unit.
You have to tell your XM radio receiver what station to send the FM signal then you tune your radio to that station. Thats how my model worked when i used it.
Feb 01, 2008 | Pioneer DEH-P790BT
Xm not working
I had a short in my TERK antenna and it gave me the same problem.
If you know someone else using xm, you can try their antenna to see if that is.
I took mine to Best Buy and they had one they checked it with.
Best of Luck.
Oct 15, 2007 | Pioneer DEH-P3370XM CD Player
DEH-P470MP and Satellite Radio Problem...
Does the unit have a built in xm decoder or are you using a separate (external) decoder? If its external i would make sure that all the fuses are fine and that the power is getting right to where it plugs into the module. Let me know of any other symptoms if you can. Cheers
May 26, 2006 | Pioneer CD Receiver - DEH-P470MP - CD/MP3...
Pioneer DEH-P4600 CD Player Logo
208 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
